So I ran a quick errand before work this morning.. I warmed up the Vespa in the garage, did my errand, and came home. When I started it up to go to work, i noticed that the idle was at a higher RPM... Not super high, but noticeably higher... Then, when stopped at traffic lights, I noticed the idle fluctuating from lower to higher... It would go up, sputter, and come back down. From low idle to high idle to sputter took about a full "one-one-thousand"...
When I got to work, I turned the Vespa off. A few seconds later, I started it back up and it idled normally...
I'm still way under warranty... Is this worth taking into a dealer over? Is it a sign of something else?
Thanks in advance!
