Fri, 17 Oct 2008 02:25:45 +0000
I assume the tires can make a big difference. Putting my 75 Super back together I mounted new tires, but they hit the exhaust. The guy I got the scoot from had just bought the tires. He said he has another set on another Super. Could I have done something wrong? The tire only mounts one way, and same for the exhaust. I need about another 1/4". Any ideas. Do I just need different tires?
![]() Fri, 17 Oct 2008 13:45:50 +0000
Posts: 6980 Location: Detroit, Michigan |
![]() 1965 Vespa SS180, 1963 Lambretta LI150
The tires should be 3.5 x 8".
Are you sure you don't have 4 x8"s on there? 4x8" were on old lambrettas, Rabbit Superflow's, old cushman's, and would rub if you mounted them. |
Fri, 17 Oct 2008 20:22:46 +0000
Rover Eric wrote: The tires should be 3.5 x 8". Are you sure you don't have 4 x8"s on there? 4x8" were on old lambrettas, Rabbit Superflow's, old cushman's, and would rub if you mounted them. |
![]() Fri, 17 Oct 2008 20:25:15 +0000
![]() Fri, 17 Oct 2008 21:26:24 +0000
1958 LD 150 Mark III, 1985 CH150D
Posts: 161 Location: Eugene, OR |
![]() 1958 LD 150 Mark III, 1985 CH150D
Wow! How many PSI are in that tire? That's some super-high tread, too.
EDIT: Last time that happened to me, I hit the exhaust on some crunchy road and it shoved into the tire. You may want to examine the exhaust mounts and make sure they're not torn, bent, or mutilated. |
Fri, 17 Oct 2008 21:32:57 +0000
What we were hoping to see Try again, perhaps? |
Fri, 17 Oct 2008 21:39:58 +0000
tire is sitting at 30PSI. The exhaust is brand new. I have yet to have this running. Still waiting for a new stator. I had thought of beating on the exhaust, but I hate to break a weld or something and be out $90
Sun, 19 Oct 2008 22:29:15 +0000
so I heated up the exhaust with a torch and beat the crap out of it with a hammer. Now the tire fits.
Moderibbit
![]() 1980 P200E - "Old Rusty", 1976 ET3 Primavera
Posts: 8892 Location: Atlanta, GA |
Sun, 19 Oct 2008 22:53:53 +0000
cigarHerb wrote: so I heated up the exhaust with a torch and beat the crap out of it with a hammer. Now the tire fits. |
![]() Sun, 19 Oct 2008 23:31:08 +0000
SawStop
Posts: 5391 Location: Puyallup, WA |
![]() SawStop
Some exhausts are like that. I bought the Sito sausage type exhaust for a smallframe and it wouldn't fit the brackets at the bottom. I called Motorsport and they said that it's just how they are, you have to bend the pipe at the head to make it fit the bike you have. I chose to make a different bracket instead of bending the pipe, I'm always afraid of weakening the metal.
