Fri, 17 Oct 2008 19:02:27 +0000
PX200E
PX200E
Fri, 17 Oct 2008 19:02:27 +0000 quote
Greetings scooteristas !
I am new to scootering, but have ridden street and dirt bikes for the last thirty years.
My current stable is two KTMs (640 adventure and a 300exc) and the charming,new to me, '90 PX200E
I have used the scoot almost daily for the last month or so and now winter is approaching.. here that means rain.. lots of rain
Brakeshoes are original piaggio that were covered in an oil-water slurry when i serviced them after the purchase, i cleaned them up with brake cleaner and roughed them up a little and they worked flawlessly until i left the scoot out in the rain one day.
To my surprise i had no front brakes whatsoever
After spending the night in the garage the brakes are yet again perfect.
Is this a common trait?
Are there other not so sensitive to moisture brakeshoes out there ?
Should there be water inside the brakedrum just from being parked outside in the rain at all?
PS Rear brake was not affected by the rain at all.. or i would have rear ended a volkswagen
Fri, 17 Oct 2008 19:57:24 +0000
Fri, 17 Oct 2008 19:57:24 +0000 quote
My front brake is useless...Rear brake and learn how to down shift...I'm sure Rover Eric will give you more insight to this.
Fri, 17 Oct 2008 20:01:31 +0000
Fri, 17 Oct 2008 20:01:31 +0000 quote
My friend complained about this on his rear tire the other day ...so we pulled the hub and found a really really tiny, slow leak of case oil onto the pads.
Now, in the front hub you don't have that... but there is grease in there to keep the bearings greased, and there's a seal to keep dirt and shoe dust from getting in the grease, and the grease from getting on the shoes.
So... i suppose if the seal on the front hub was bad, that COULD be happening, but i think it unlikely.
i'll keep brainstorming.
Fri, 17 Oct 2008 20:05:43 +0000
1958 LD 150 Mark III, 1985 CH150D
Fri, 17 Oct 2008 20:05:43 +0000 quote
I've also had this problem with the front brake. It all went away when my rear hub went out of true and I started relying on the front brake. A good thing to do after a rain is to ride the bike slowly (or walk it forward) while applying the front brake slightly. When it starts catching, you're ready to go, although you'll want to test it a bit before entering traffic.
The front seal on hubs I've personally seen isn't exactly watertight, but I don't have enough experience with that part of the bike to definitively tell you. Thankfully, you can still rely on the rear brake, which is typically the strongest on vintage scooters (there being the most weight over it).
Fri, 17 Oct 2008 21:04:20 +0000
PX200E
PX200E
Fri, 17 Oct 2008 21:04:20 +0000 quote
Thank you for your input guys, i think the water-oil slurry i saw inside the front hub was from the previous owners pressure washing the bike before selling it.
i Just found it odd that rain water could reduce the stopping power from virtually "stoppie" to nil
Now that the brakes are dry they are back to near disc brake performance.
Guess i will just have to get used to it and rely more on the rear brake
BTW
I have surfed through quite a few scooter forums the last weeks and this place seems to be the best source for tech tips
Wibbo
Fri, 17 Oct 2008 22:39:56 +0000
One of each
One of each
Fri, 17 Oct 2008 22:39:56 +0000 quote
What about a Grimeca disc kit for the front?
OP is in Europe, so other than the taxes, it should be cheap....
Fri, 17 Oct 2008 23:09:58 +0000
Fri, 17 Oct 2008 23:09:58 +0000 quote
That's bolt-on for a P. right?
Sat, 25 Oct 2008 11:32:16 +0000
Destroyer of Worlds
LML Star 125, Vespa GT200
Destroyer of Worlds
Sat, 25 Oct 2008 11:32:16 +0000 quote
Yes and no.
The semi-hydraulic (cable-operated master cylinder on the fork) can be done bolt-on, but the fully-hydraulic (lever-operated master cylinder on headset) version requires a new (or modified) headset.
Sun, 26 Oct 2008 08:30:36 +0000
'10 GTS 300 Super, '79 Vespa P200E, '04 Vespa PX200, 2011 SportCity 300 Cube [Sold]
Sun, 26 Oct 2008 08:30:36 +0000 quote
thefuzzylogic wrote:
Yes and no.
Can you provide some more detail on this? I started researching semi vs. fully-hydraulic disk kits. IF you go fully-hydraulic, you need a new fork and headset? I'm not exactly sure why?
Sun, 26 Oct 2008 08:35:07 +0000
Destroyer of Worlds
Destroyer of Worlds
Sun, 26 Oct 2008 08:35:07 +0000 quote
Yeah, AFAIK the only full-hyd kit is only for the 20mm axle found on later P-range bikes. Your (and my) '79 have the old 16mm axle. I'm not sure, but I'd bet even the Grimeca 16mm semi-hyd kit can be set up fully-hydraulic by using a different master cylinder. I'm not sure, though, because I don't have one to try out.
Sun, 26 Oct 2008 08:38:06 +0000
Sun, 26 Oct 2008 08:38:06 +0000 quote
Yeah, thats exactly what I was wondering! I'm guessing youc an buy different master cylinder units quite easily?
Sun, 26 Oct 2008 08:42:54 +0000
Destroyer of Worlds
Destroyer of Worlds
Sun, 26 Oct 2008 08:42:54 +0000 quote
Yeah, go to any Genuine dealer and order a Stella headset from them. You might need to drill a hole for your ignition key since it's on the column on those bikes, but the rest should match.
⚠️ Last edited by ianp on Sun, 26 Oct 2008 08:45:45 +0000; edited 1 time
Sun, 26 Oct 2008 08:45:12 +0000
Sun, 26 Oct 2008 08:45:12 +0000 quote
Yeah, go to any Genuine dealer and order a headset from them. You might need to drill a hole for your ignition key since it's on the column on those bikes, but the rest should match.
Wouldn't I need to also buy a hydraulic cable to go down to the brake? Curious, why most people don't do this?
Sun, 26 Oct 2008 08:46:33 +0000
Destroyer of Worlds
Destroyer of Worlds
Sun, 26 Oct 2008 08:46:33 +0000 quote
Yeah, thst's a standard auto part. Get some braided brake cable in whatever inner diameter the kit is (you will have to measure it.)
Sun, 26 Oct 2008 08:49:03 +0000
Sun, 26 Oct 2008 08:49:03 +0000 quote
Hmmm, will look into it. The brake disk and pad units would be the same between the two?
Sun, 26 Oct 2008 09:12:13 +0000
'91 PX200e
'91 PX200e
Sun, 26 Oct 2008 09:12:13 +0000 quote
Can't see what all the fuss about a front disc is.
Matt
Sun, 26 Oct 2008 09:13:08 +0000
Sun, 26 Oct 2008 09:13:08 +0000 quote
Matt
My front brake isn't very good at stopping the hulking machine. Disk brake has much better stopping power.
Sun, 26 Oct 2008 09:47:31 +0000
Destroyer of Worlds
Destroyer of Worlds
Sun, 26 Oct 2008 09:47:31 +0000 quote
The kit would come with all the lower stuff. Disc, caliper, pads, etc... The only part you would replace theoretically would be the headset/mastercylinder and brake line.
Sun, 26 Oct 2008 09:52:09 +0000
Sun, 26 Oct 2008 09:52:09 +0000 quote
Theoretically..hehe, I've had that blow up in my face a couple times...would be interested to see if this has EVER been done before or are we on the frontier of grimeca brake installation on 16mm forks??
Sun, 26 Oct 2008 09:54:14 +0000
Destroyer of Worlds
Destroyer of Worlds
Sun, 26 Oct 2008 09:54:14 +0000 quote
Well, the Grimeca kit is designed for 16mm forks. There's a 16mm version specifically for our bikes. The untested part is abandoning the semi-hyd master cyl in favor of the fully-hyd headset off a Stella or '98+ PX150.
Sun, 26 Oct 2008 10:00:37 +0000
'91 PX200e
'91 PX200e
Sun, 26 Oct 2008 10:00:37 +0000 quote
Wangta wrote:
Matt
Yeh I know that, I ride motorcycles as well where the bigger the disc the better.
What I'm trying to say is you've got to put it into perspective.
BHP= minimal
Top speed= low
Drum brakes= more than adequate if you ride accordingly and have them set up well.
And it looks cooler too. 8)
Matt
Mon, 27 Oct 2008 01:10:31 +0000
2007 GT200 1979 P200E 1980 P200E 2011 Triumph America
Mon, 27 Oct 2008 01:10:31 +0000 quote
I have one 80 P200E that is original drum. The other 79 P200E was upgraded to the semi hydro disc. You have to be careful when you ride the disc brake as it will really grab compared to the drum. I havn't had to change the brake pads on either yet but I would say the disc will be easier. Also the one with the disc I tend to use it more than the rear brake at slow speeds which I think ends up saving the wear on the rear brake shoes.
  DoubleGood Design
[ Time: 0.0441s ][ Queries: 3 (0.0215s) ][ Debug on ][ 298 ][ Thing Two ]
