Sat, 18 Oct 2008 02:13:05 +0000
'91 PX200e
'91 PX200e
Sat, 18 Oct 2008 02:13:05 +0000 quote
I'm not sure if this has been covered before, too lazy to search.
What do people do to secure your drum braked Vespa.
Those disc braked wimps have slots in the wheels to pass a chain but I can't work out how to secure the little sucker.
I have seen the bar/front brake type of clamp lock, maybe thats the best way to go.
As usual, suggestions very welcome.
Cheers,
Matt
Sat, 18 Oct 2008 06:31:58 +0000
Sat, 18 Oct 2008 06:31:58 +0000 quote
I have used a stout 1 inch (25mm), armored cable passed through the area shown in yellow on the fork, passing it over the top of the tire.
When Ardy and I were traveling in Italy, we simply cabled the front of both scoots together, making a quick "lift and snatch" awkward.
When cabling my scoot solo, I run the cable through the fork and back around the leg shield to make it awkward to roll off. Obviously, it's better to cable it to a solid object, like a lamp post, if one is available.
This may not be the most guaranteed protection against a determined, knowledgeable thief, but it does discourage the run of the mill clown.
Al
Sat, 18 Oct 2008 06:44:56 +0000
'10 GTS 300 Super, '79 Vespa P200E, '04 Vespa PX200, 2011 SportCity 300 Cube [Sold]
Sat, 18 Oct 2008 06:44:56 +0000 quote
Do the vintage Vespas, like a p200, have good/strong enough electrial systems to power an alarm from Scorpio or guerilla (SP?)?
I installed a Scorpio on my GTS and really like it - its so freakin loud I can't imagine anyone trying to lug that thing away with it blaring.
Sat, 18 Oct 2008 06:51:39 +0000
1958 LD 150 Mark III, 1985 CH150D
Sat, 18 Oct 2008 06:51:39 +0000 quote
Re: Security, or how to hold on to your Vespa.
Keep an eye on your bike and come out swinging!
Sat, 18 Oct 2008 11:14:13 +0000
Destroyer of Worlds
LML Star 125, Vespa GT200
Destroyer of Worlds
Sat, 18 Oct 2008 11:14:13 +0000 quote
You would have to calculate it, but I would guess not. The battery on the P is more for load balancing rather than actual power. It's just there to keep the lights from dimming at idle.
As for security? I lock the seat, shut off the fuel tap, and lock the steering. That way, nobody is going to ride off with it. If they want to toss it in the back of a truck, nothing short of a ground anchor is going to stop it. I do use a cable lock around the front shock when it's convenient, but much of the time there's nothing to lock to.
Beyond that, I've got full-coverage insurance. P-range bikes are a dime a dozen around here. I'll just buy a new one if this one gets jacked.
Sat, 18 Oct 2008 14:18:11 +0000
Sat, 18 Oct 2008 14:18:11 +0000 quote
Also, Ian, if I am not mistaken, US battery P models had the battery to power the brake light to meet safety regs. Needed a brake light that worked even if the engine failed, IIRC. Subsequently, electric start was added.
Al
Sat, 18 Oct 2008 17:02:00 +0000
Sat, 18 Oct 2008 17:02:00 +0000 quote
Al
Blinkers were a U.S. requirement as well. In fact, most of the crazy DC system was probably from U.S. requirements.
Sat, 18 Oct 2008 18:24:59 +0000
Sat, 18 Oct 2008 18:24:59 +0000 quote
+1
I like that idea
Sun, 19 Oct 2008 01:04:39 +0000
Sun, 19 Oct 2008 01:04:39 +0000 quote
Thanks fuzzylogic - that makes sense. This might be another really stupid question (my manual is in the mail now;)), but does the P200 have an alternator that charges the battery?
Sun, 19 Oct 2008 03:10:42 +0000
bunch "o" bikes
bunch "o" bikes
Sun, 19 Oct 2008 03:10:42 +0000 quote
Yes P's have a "stator" that produces AC voltage which is then rectified to produce DC V. to charge the batt.
Batteries were added for US market bikes so you had a tail light and horn when your stuck on the side o the road at night with your brokeass scooter
Mon, 20 Oct 2008 04:18:32 +0000
2007 GT200 1979 P200E 1980 P200E 2011 Triumph America
Mon, 20 Oct 2008 04:18:32 +0000 quote
I installed a gorilla alarm on mine. I have a post under "gorilla alarm". It works great. I also have a battery tender that I will occasionally use.
Mon, 20 Oct 2008 04:23:48 +0000
Mon, 20 Oct 2008 04:23:48 +0000 quote
Wow, nice - didn't think you could do that on a PX series! Awesome! Here is post by the way:
http://www.modernvespa.com/forum/topic33154
Tue, 21 Oct 2008 18:17:25 +0000
1981 P200E
1981 P200E
Tue, 21 Oct 2008 18:17:25 +0000 quote
I got an On Guard lock, which I wrap around the floor board and then lock to a metal pole.
I also put a bumper sticker from the local shooting range on my glove box
it says "have you hugged your machine gun today."
oh, and my neighbor has a new and shiny scoot. mine is dented and a little rusty...so it's definitely not first pick in the eyes of the little hood kids that ride around on asian bike-in-a-box scooters trying to steal other people's shit....plus they probably couldn't make it out of the parking lot on a manual.
now if it caught the eye of a professional thief for whatever reason, I'd probably be screwed, but it would take a while to cut through that On Guard chain.
Tue, 21 Oct 2008 18:19:00 +0000
Tue, 21 Oct 2008 18:19:00 +0000 quote
Do P series scooters have that little metal loop on the bottom for passing through cable etc?
Tue, 21 Oct 2008 18:22:09 +0000
1981 P200E
1981 P200E
Tue, 21 Oct 2008 18:22:09 +0000 quote
sorry for the double post.
This one is a lot like the disc alarms, but you can put it anywhere on your bike, and it will go off at 100db if it is moved.
http://toolmonger.com/2008/06/11/its-like-a-car-alarm-for-the-rest-of-your-stuff/
I don't have one yet, but my friend does. It's only $20 and it works.
Tue, 21 Oct 2008 18:26:46 +0000
Tue, 21 Oct 2008 18:26:46 +0000 quote
$20..wow. That's a fair price.
  DoubleGood Design
[ Time: 0.0318s ][ Queries: 3 (0.0100s) ][ Debug on ][ 298 ][ Thing Two ]
