Can you put aluminum grips for a "modern" PX (PX150) or GTS onto a '79 P200E?
![]() '10 GTS 300 Super, '79 Vespa P200E, '04 Vespa PX200, 2011 SportCity 300 Cube [Sold]
Posts: 2923 Location: San Francisco, CA |
Sat, 18 Oct 2008 21:18:42 +0000
Anybody know where you can get the aluminum grips for a PX? See pictures below.
Can you put aluminum grips for a "modern" PX (PX150) or GTS onto a '79 P200E? ![]() ![]() |
RIP
![]() 2006 PX 150 & Malossi Kitted Malaguti Yesterday (Wife's)
Posts: 12955 Location: Paros Island, Greece |
Sun, 19 Oct 2008 13:20:08 +0000
Wangta
If you are talking about the current, stock grips, they are the most uncomfortable grips in hot weather that I have ever dealt with. No air circulation, and then as they get wet from perspiration, they get quite sticky. During hot weather, I have to hold on with my fingertips every so often to allow the moisture to evaporate. On our tour of Italy, when the temps were in the 90's, I had to do this very ten minutes or so! In cold or moderate temps, they are fine. Al |
![]() 1975 Rally 200 (Femsatronic)
Posts: 97 Location: Denver |
Sun, 19 Oct 2008 18:18:30 +0000
You can get those at most harley shops. you'll have to shim them with tape or something though as they run a little too large for the handlebar tubes. I have a pair on my Rally and i used electrical tape and hairspray on the throttle side, for the shifter side i had to use electrical tape and a self tapping screw to use as a set screw.
![]() 79 P200e, 81 100 Sport
Posts: 1443 Location: Iowa |
![]() '99 PX200 & GTS300 HPE SuperSport
Posts: 1465 Location: Cheshire, England, UK. Still European |
Sun, 19 Oct 2008 19:16:46 +0000
Aviator47 wrote: Wangta If you are talking about the current, stock grips, they are the most uncomfortable grips in hot weather that I have ever dealt with. No air circulation, and then as they get wet from perspiration, they get quite sticky. During hot weather, I have to hold on with my fingertips every so often to allow the moisture to evaporate. On our tour of Italy, when the temps were in the 90's, I had to do this very ten minutes or so! In cold or moderate temps, they are fine. Al These are on my P2... ![]() |
