Hi guys, I have always found this the best place to get all sorts of info.
Now I need your help.
I have a VERY steep driveway, about 23 degrees. It slopes down to the road. Today as I was leaving for a ride a very scary incident happened. I throttled on as usual and noticed that the yellow suspension light was still on as I was moving down the driveway. Meaning that the suspension was still locked. Sure enough it wouldn't steer. I saw the letterbox coming right at me!! By this time I was off the concrete and onto our front dirt/rocks/grass bit. I managed to apply the brakes heavily and I slid to a stop at the steepest part, by this time the scooter was at a very odd angle. I quickly decided that it would be a good idea to apply the handbrake, which I did. I ten shut off the engine. I had my phone in my pocket and called my 17 y.o daughter who was the only one home to come and help. Shortly after the nice fellow from across the road came and offered to help. We decided that it would be a good idea to ease off the handbrake and get it back on reasonably level ground. ie; the road. So I started it up and went away no problems.
While I was riding I was thinking what if it happens again? So I decided that I wouldn't lock the suspension at traffic lights until I could get somewhere quiet and test it. I almost had the courage to lock the suspension a a set of traffic lights and locked it. i then chickened out and unlocked it before the light turned green. Immediately after, the red suspension warning light came on. At the next set of lights I quickly shut the engine off and re-started it and the red light went out. Phew.
I've made it home, didn't stop and check whether the suspension would unlock from running.
It's parked, I didn't drop it and I'm physically unhurt.
What I'm asking from you all is: is it operator error OR should I take it to my dealer to have a look at??
