Tom Crusaders SC wrote:
but... after removal of fuel line from carb, when i cranked the engine very little gas "dribbled" out of the line, but after it was done cranking the fuel flowed freely for about a second or so..? vacuum pump? or carb's vacuum circuit?
Rather than a manual fuel tap, your scoot has a vacuum actuated tap. Carb creates a vacuum when the engine is turning, and that vacuum is transmitted to the fuel tap at the tank and opens it. This is also used on modern 2T engines.
You now need to isolate why fuel didn't flow freely while cranking. Disconnect the the vacuum line from the carb with the fuel line disconnected from the carb, and draw a vacuum on the vacuum line. You should be able to do this by simply sucking on it. If the fuel doesn't flow, take the gas cap off and try again. If the fuel flows, you have a vent problem, although I doubt this because ambient pressure would give you a reasonable initial flow. But it's such an easy step, do it anyway.
When you suck on the vacuum line, it should feel like sucking on a capped tube. If there is constant air flow, the line is leaking or the tap has a vacuum leak. It's really a simple system. If manually drawing a vacuum works and you get fuel flow, then the problem is in the carb. I don't know enough about that carb to help. Of course, the vacuum line could have been poorly sealed at the carb. Check that.
If manual vacuum doesn't get fuel flowing, then you have either a clogged vacuum line, a clogged fuel line or a clogged/bad fuel tap. Check them now.
It's really a simple system. The electrical connection at the carb is most likely the automatic choke. Again, no big deal, and probably not your problem.
Al
