RIP
'06 Vespa GTS 250 i.e., '77 Vespa P200
Posts: 1260 Location: Bay Area, CA |
Turn on the micro function on your camera
Belt is out of focus but those shoes are tight! (and nicely in focus) |
RIP
Good catch on the belt. Bound to save some grief if you take Val's advice.
I hadn't been as attentive; mine disintegrated on the freeway a little over 200 miles from home in 110+ degree heat *ugh* Love the shoes! |
Posts: 14987 Location: The state of insanity, SoCal |
psst! val! psst!
:whispering: i can see your crotch! all kidding aside, good catch. the way you ride you'd have eaten that belt in no time. glad to hear that you've got your ride back, too. best, -greasy |
Had 2 2006 GTS 250ie's
Posts: 2025 Location: NW Tennessee |
Posts: 1725 Location: Grand Pothole Rapids, Michigan |
I can't believe that people will not replace belts, tires, hoses, and other rubber parts....I check them in my cars, scoots, every time I open the hood, and variator covers.....
I replaced the belt in my scoot, when I put on my kit...Everyone should replace their belts every 4000-5000 miles, or every 5 years....at the most on a scoot! I replaced the fuel hoses in my 88 Yamaha, when I saw black specks in the float bowl, and replaced the fuel tap with a modern one from a vino....with the alcohol in the fuel today, it eats up the old fuel hoses fast! Check your rubber parts for blisters, cracks, bubbles, softness or hardness at least once a year.... ⚠️ Last edited by greg531 on UTC; edited 1 time
ks7877 wrote: Good catch on the belt. Bound to save some grief if you take Val's advice. I hadn't been as attentive; mine disintegrated on the freeway a little over 200 miles from home in 110+ degree heat *ugh* Love the shoes! |
Posts: 4181 Location: San Jose CA |
and don't forget the variator...
check your Costa variators too....
7000 miles and the variator was worn out also... the bushing wears into the 1mm washer....on its way toward eating the fan side pulley half.....not good. But then again the girl rides hard.... R 8) |
I rode my Scarabeo like hell, and never once did I completely wear out a belt before changing it. Although, I probably should have changed it way more often than I did. 3 belts in 16K miles. I think I got lucky on a lot of parts with that scoot.
I always had a Malossi belt on my Scarabeo. Does Malossi do well for the 250 Vespas, too? What are some of the better brands right now? I've got a parts/accessories coupon good for about the time I should pick up my GTV, and I'm not opposed to picking up a couple spare things while they're cheaper. --not meant to be a thread-jack-- |
3337 wrote: ks7877 wrote: Good catch on the belt. Bound to save some grief if you take Val's advice. I hadn't been as attentive; mine disintegrated on the freeway a little over 200 miles from home in 110+ degree heat *ugh* Love the shoes! Fortunately (?) it didn't turn into a pile of spaghetti like ifixjets' did. Mine came apart into a bunch of 1-2" pieces. |
ks7877 wrote: 2 years, +/- 17,000 miles on the scoot and 3 weeks +/- 6,500 miles on the belt (not a typo) I changed my belt on Day Six of Cannonball, with only about 2000 miles on it. I couldn't afford to have it break during the event. |
21 75th Anniv. Primavera, 10 GTS Super 300, 64 Allstate, 61 VNB, 61 GL, 61 Lammy LI 125 Mahi Shriner, 57 Lammy LD125
Posts: 1410 Location: Baltimore-Washington-Asbury Park at the Jersey Shore |
First thing I noticed was the shoes. Nice!
On the Cannonball my GTV belt broke for Joel (with maybe 3,000 miles on it) just a couple days after Rolf looked at it and said it seemed OK. Hard riding in hot weather is definitely hard on belts. |
El Josh AKA Ruby wrote: Turn on the micro function on your camera Belt is out of focus but those shoes are tight! (and nicely in focus) |
(GT200L) ... no more scoot :o(
Posts: 1168 Location: Riverside, CA, USA |
zteverhart wrote: How difficult is it to change the belt? I see you have the GTS: Variator & Belt change - Pictures from MV workshop You will need the GTS variator tool: http://www.scooterwest.com/item_detail/Variator-Holder-GTSGTV/1969/ About $140.00. |
I'm curious, who manufactured the belt?
I've arbitrarily decided to replace the belt, rollers, and variator nut on my ET4 every 8K miles, so my next change will be due in a week or two. With several different belt offerings out there, I'm trying to decide which belt to order this time. Incidentally, my first OEM belt looked just fine (visually) at 8K miles. I replaced it with the Malossi belt, which is still on now. It's given me no problems so far. We'll see how it looks when I change it out. |
greasy125 wrote: psst! val! psst! :whispering: i can see your crotch! |
I'm due before too long. I replace the OEM with a Kevlar belt, I think it was the Malossi.
The Kevlar is less expensive, but I think I will go with the OEM again next time. My CVT has a moan to it on take off after the change. I may not have cleaned the clutch plates well enough. |
Posts: 44097 Location: Pleasant Hill, CA |
RIP
elmonchichi wrote: greasy125 wrote: psst! val! psst! :whispering: i can see your crotch! this is my 3rd belt. they've all been stock, and none of them have cracked like this one. it was so much fun ripping into the Costa that i had another one put on. 22K miles on the bike. she's quick again. |
valincal wrote: This was at 7k miles greasy125 wrote: the way you ride you'd have eaten that belt in no time. |
WHOoligan
Posts: 6695 Location: Los Angeles Kings, Stanley Cup Champions X2 |
WHOoligan
Replaced my first belt at 5900 mile just as a precaution. Noticed ridges on the front pulley, lost top end, could never regain top speed. I thought the extended warranty should have covered this at that milage, but I guess not.
. Replaced second belt at 1100 miles with front pulleys. Power and top speed is back. It seems with every belt change one can expect to get that grinding sound in the clutch from the new belt. Correct me if Im wrong. Manny |
Posts: 16295 Location: Toronto, Canada, Fort Lauderdale, Florida |
snapshot05 wrote: Replaced my first belt at 5900 mile just as a precaution. Noticed ridges on the front pulley, lost top end, could never regain top speed. I thought the extended warranty should have covered this at that milage, but I guess not. . Replaced second belt at 1100 miles with front pulleys. Power and top speed is back. It seems with every belt change one can expect to get that grinding sound in the clutch from the new belt. Correct me if Im wrong. Manny |
WHOoligan
WHOoligan
Benito wrote: snapshot05 wrote: Replaced my first belt at 5900 mile just as a precaution. Noticed ridges on the front pulley, lost top end, could never regain top speed. I thought the extended warranty should have covered this at that milage, but I guess not. . Replaced second belt at 1100 miles with front pulleys. Power and top speed is back. It seems with every belt change one can expect to get that grinding sound in the clutch from the new belt. Correct me if Im wrong. Manny Fucking transmissions. |
