Tue, 21 Oct 2008 14:41:58 +0000
64 Vespa 150cc
64 Vespa 150cc
Tue, 21 Oct 2008 14:41:58 +0000 quote
For a VBB, VNB and other vintage bikes, is it customary to richen the mixture for the cold weather months?
Tue, 21 Oct 2008 14:44:52 +0000
Tue, 21 Oct 2008 14:44:52 +0000 quote
i tend to run a hotter plug ( b6ES for Lambrettas / P-series, ...BHS for your VBB ) ... to make it easier to start.
And it's going to take a little longer to warm up.. but other than that, should be the same as always. I wouldn't screw with your jetting.
Tue, 21 Oct 2008 17:58:58 +0000
64 Vespa 150cc
64 Vespa 150cc
Tue, 21 Oct 2008 17:58:58 +0000 quote
what are the different plug choices? ie: what do you run in spring/summer and winter/fall. I converted the piston to a dome type with the appropriate head when I rebuilt the motor and there is a champion RN2C in there now, I believe.
Tue, 21 Oct 2008 18:00:32 +0000
Tue, 21 Oct 2008 18:00:32 +0000 quote
I always run NGK plugs .. normally B7's, but in winter i go to B6's.
For your bike, look up the champion / NGK conversion of NGK B6HS
Tue, 21 Oct 2008 18:02:46 +0000
64 Vespa 150cc
64 Vespa 150cc
Tue, 21 Oct 2008 18:02:46 +0000 quote
Does the conversion change the spark plug rating? There is also 2 types of plugs long and short-whats the difference?
Tue, 21 Oct 2008 18:20:39 +0000
Tue, 21 Oct 2008 18:20:39 +0000 quote
No ..there's an equivelency chart that gives the comparitive plug between brands.
Short threaded plugs tend to go in all smallframes, non-sport models, ( VBBs/Sprint / Super ) .... long threaded plugs go in any sport model ( GS / SS / Rally / P200 ) and all lambrettas.
Tue, 21 Oct 2008 18:30:10 +0000
64 Vespa 150cc
64 Vespa 150cc
Tue, 21 Oct 2008 18:30:10 +0000 quote
I meant the cylinder head/piston conversion-does this change the spark plug rating.
Tue, 21 Oct 2008 21:13:11 +0000
Destroyer of Worlds
LML Star 125, Vespa GT200
Destroyer of Worlds
Tue, 21 Oct 2008 21:13:11 +0000 quote
Also, I'll note: P200s take the B*ES (long) plugs, but 125s and 150s take the B*HS (short) plugs.
  DoubleGood Design
[ Time: 0.0276s ][ Queries: 3 (0.0072s) ][ Debug on ][ 298 ][ Thing Two ]
