ummgood wrote:
Over time I have stopped using my gauge to check the tire pressure but I still push on the tire with my boot to make sure it has air. I think it is still important to check them more than once or twice a month. A blowout on a bike is much worse than a blow out in a car.
All it takes is one small nail or brad in your tire and one morning you could have half your air. (For what it's worth I also leave every morning at 6:00 on my commute and I think it is worth my life to take the 1 or 2 minutes extra to check my tires.)
You need to use a gauge. I had a nail in my rear tire, backed out of the garage and noticed it was harder to push it back, so I got off and kicked the tire, IT SEEMED fine. Got up to the first turn I do at speed and almost lost it as the tail end came around. Don't trust kicking or pushing on the tire. It can seem fine and be low enough to make you wreck.
If I hadn't had lots of experience on the dirt doing lots of power sliding, I may have laid it down, but my dirt bike skills automatically kicked in and saved me.
Wayne B
