I think the first thing I would check would be the battery.
Do you know if it's the original? Also, are you doing short trips?
ET4...no start
Battery problem
from
Commuters - how often do you charge?jimc wrote:
Oh dear the perennial question...
If your vehicle (car/bike/whatever) starts first time within 5 secs then there's no problem with battery or charging system - but do check wet batteries every week for levels. Less than 5 miles a day will not keep the battery in tip-top condition though.
The bike takes several goes to start? There is a problem, may be minor, may be a symptom of problems looming...
Leader engines have poor generating capacity - often down to one or more useless magnets. Best to upgrade from 7AH to 12AH batteries if they will fit and use a battery tender. Do not fit high current usage add-ons like heated grips. GPS etc is fine of course. Also remember that poor starting/cold running on a Leader engine can just be tight valve clearances - this was sorted years ago, but some DIY owners may not have heard...
Quasars can deliver more current from their set - so heated grips are OK, but again upgrading the battery helps with starting and a battery tender is advised, but not as essential.
Master engines have plenty of spare capacity - but this has its own problems, cables and connections burn out if there is even a tiny fault. Check the battery frequently, consistent low levels of electrolyte mean the regulator is faulty - loss of capacity within a few weeks of non-use is another symptom. However these are robust enough that frequent topping up with de-ionised water and use of a battery tender can cope with a faulty regulator for a while - but just be aware of the possible consequences.
E&OE of course...
Good Luck with it & let us know how you make out.
Regards
Harvey
