@davids_allstate avatar
'61 Allstate / Vespa VNA with a '69 veloce 150
Hello every one.
As I have mentioned in a previous post, I have a 1961 Allstate, which is comparable to the VNB1T Vespa. I am rebuilding the motor at this time and have the old Dell'Orto UA 16 SI carburetor. It too is in many pieces and I was told it is near to impossible to get rebuild kits and bits. I have been offered a Spaco SI 20, labled P1054. Does anyone know if this is compatable to my VNA1M stamped, piston port 125?
Please help.
-David
@rover_eric avatar
@rover_eric avatar
No. it is absolutely NOT compatible.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Eric your pic looks so menacing now. That might put an end to the idolizing fans Razz emoticon
@rover_eric avatar
@rover_eric avatar
If a complete carb for that engine is worth something to you, i might have a hookup.
And i don't want any fans. It's creepy.
GT200
GT200
David... did you check with Eurocarb Ltd.? - www.dellorto.co.uk ?? I'd be surprised if they couldn't help you. You may have to contact them directly because they often have stuff not listed on the site.
Thanks for the link.
Thanks for the dellorto uk link.
I'll check 'em out!
-David
And just to let every one know why I ask so many questions, this is my first vespa. I am learning as I go, so thank you for your patience.
carb as it is
Well, I sat down and looked at all the pieces.
I have these in the pictures, but I don't have a schematic to know what is missing. Can anyone help? Does this look usable?
-David
carb
No air box or rubber piece that goes through the body to get fresh air...
I think I can find those at scooterworks or scooterpartsdirect.com....
Any specific way to make sure it's in workable condition before I buy an other one?
-David
s 150, vnb 2
s 150, vnb 2
You can get a pdf copy of a vnb parts manual at scooterhelp.com.
Very useful.
http://www.scooterhelp.com/serial/vespa.parts.html
⬆️    About 9 years elapsed    ⬇️
1960 cruisaire vespa
HI Guys,
I also am new to vespa and have almost completed a resto on a bike that sounds much like the one I the thread, also struggling with the Carb as when I turn the fuel on the carb just overflows immediately, would like to see a diagram of carb or know of a direct replacement (new) or a used float chamber with innards.ps, based in UK.
VESPA
VESPA
That carb is so touchy and finicky. Best bet is to do a total rebuild and leave it soaking in some gas or carb cleaner to clean out the jets and any crevices that might have build up.
Provided is the link to a VNA carb rebuild:
http://www.scootermercato.com/Scooter-Parts/Carb-Gasket-Kits/CGUA16
SIP has the PDF document along with a list of parts to order for the carb:
https://www.sip-scootershop.com/main/service/PartsCataloguesList.aspx?dim=old&cat=13692FCD-65DA-4BA3-B9F8-6863F1EB353E&_language=
Good Luck!
Great info. Thanks very much. Funnily enough, I was standing in the queue in my local lambretta store and a guy said to me I have one of those and gave me it gratis!
This vespa thing is definatly feeling like a community.
Steve
⬆️    About 5 years elapsed    ⬇️
Vespa Allstate VNA
Vespa Allstate VNA
Hi, I just acquired a VNA from 1960
, vespa Allstate.
It seams I have the same problem.
Would you have the steps to clean and make sure the pieces are here?
Some of the links shared above are not active anymore. A video or a pdf would be very helpful. Thanks to everyone.
Charles
[ Time: 0.0198s ][ Queries: 4 (0.0138s) ][ live ][ 313 ][ ThingOne ]
