Where exactly do the underbody clips clip onto? Please, someone who can help me out quick. Trying to do it right now!
2005 GT 200L Grigio_Smoky a.k.a. "Il Grande Lebowski"
Posts: 3028 Location: B'game, CA |
I'm not going to be any help at all here, but had a question: where did you get your Thermoscud? Did you import it directly, or is there a shop here in the U.S. that carries them?
I'll also be interested to hear your review once you have it installed! Hope someone has your answer. |
I got mine through MV last year, a very wonderful member organized the whole thing, collected the money and got them shipped from Italy.
Gobshite Shiva
Posts: 14960 Location: London UK |
you can attach the underside clips to any convenient opening in the bodywork. if there's only one underside clip, make sure you attach it somewhere reasonably central. if there are two, make sure they're more or less symmetrical. then make sure you pull all the straps good and tight and half-hitch any dangling ends.
Look underneath the legshield behind the front wheel on the bottom you'll see places along the edge of the metal where you can attach the clips. They just hook onto the edge, then the straps can be pulled tight.
I've not attached mine yet this year, though a couple of mornings at 6:00 am on my way to work, my legs got pretty cold. Northern California is still pretty mild this time of year, so I'm trying to tough it out as long as possible. Also, I've been in denial since I learned by reading threads in the German Vespa forum that Thermoscud and other scooter aprons are called "Retirees Blankets" |
Gobshite Shiva
Monad007 wrote: Also, I've been in denial since I learned by reading threads in the German Vespa forum that Thermoscud and other scooter aprons are called "Retirees Blankets" |
2005 Dragon Red Vespa ET4 Speedster
Posts: 2109 Location: Rappahannock Co., Virginia |
Where did the summer go?
You can always tell winter is upon us when the talk turns to Termoscud. |
Well, I attached it before I saw these posts. I did attach it to a sort of open spot underneath, it just doesn't really clip INto anything, they just sit there. Hopefully they hold. Thanks.
Also, I doubt I'll EVER be able to retire at this point, (even if I were close to that age), but in Michigan.., cold is cold and I could care less if my reputation is in question or my age! |
Yeah you're right. The clips don't really clip into anything, they just hook onto the frame with the tension from the straps to keep them there.
Monad007 wrote: No way, Kim. I luv my scud - got me through the Winter last year. had to try. gotta get a scud for the winter. |
Gobshite Shiva
bjmedd wrote: Well, I attached it before I saw these posts. I did attach it to a sort of open spot underneath, it just doesn't really clip INto anything, they just sit there. Hopefully they hold. Thanks. |
21 75th Anniv. Primavera, 10 GTS Super 300, 64 Allstate, 61 VNB, 61 GL, 61 Lammy LI 125 Mahi Shriner, 57 Lammy LD125
Posts: 1410 Location: Baltimore-Washington-Asbury Park at the Jersey Shore |
Bonnie: where is Owen when you need him?
Genie: what on earth are you doing up at this indecent hour? |
Gobshite Shiva
Bobovespa wrote: Genie: what on earth are you doing up at this indecent hour? |
Pics of the way I put my lap blanket on
(I can't guarantee this is right, but it works for me) Velcro attachment at top: Middle strap: Lower strap: |
Bobovespa wrote: Bonnie: where is Owen when you need him? Genie: what on earth are you doing up at this indecent hour? |
Darn right. I can't even get mine to come to a local rally, although for some reason she was willing to go to San Francisco last month.
