Greetings everyone.
I have a P200 that used to run like a champ, then I (stupidly) let it sit for over a year while I remodeled my basement.
I pulled out the gas tank and cleaned it out, and also rebuilt the carb (with help from a friend).
Now I can get it to start, and it will idle just fine indefinitely. However, it chokes out and dies about 10 seconds after I take off.
I can then restart it just fine, and it will idle no problem again, but as soon as I take off the same thing happens.
If I rev it high while in neutral it also dies off after several seconds.
When it dies, it sounds like it has when I've run out of gas in the past, so I'm thinking that the problem is with the fuel getting through somehow.
I asked around a bit, and most of the suggestions were to check and clean the main jet, which I did when I had the carb open.
Any other suggestions? I'm at a loss and it's killing me to see it sit in my garage.
Thanks much everyone.
--Casey
