pointpergame wrote:
Just a heads up: there is no (non-heated) glove that can keep your hand warm in cold weather. The conduction is just too great for your body to overcome.
For me, the breakpoint is around 61-deg F. Ski gloves can take me down to 58 or 57 degrees. I'm talking about 5 minutes and I'm in trouble. You might look into wind chill ratings of ski gloves to see how low you can go.
61 degrees F is your breakpoint for cold hands? Geez, you do have bad gloves, man!
I find I can ride comfortably down to just above freezing temps without getting cold hands! The secret?
1} Make sure you have a windshield on your scoot that blocks most of the direct wind blast away from your hands. VERY IMPORTANT!
2} Good gloves? Forget those thickly padded "ski gloves"! I use the JR Ballistic gloves. These are amazingly warm gloves for being so freaking thin! They have a tough wind-blocking outer shell over a loose inner liner that retains heat amazingly well!
In fact these JR Ballistic models are the warmest gloves I've ever worn in 28 years of motorbiking (including all-winter Polar Bear Club MC rallies)! They're warmer even then the thickly padded Olympia snowmobile type gloves I have!
They're also advertised as waterproof, but if they are they're only slightly so..
-But warm? -Sheesh, using these, combined with a wind blocking shield on the bike, I've never felt the need to even consider 'heated' gloves!
I have the 2005 JR Ballistic model gloves that I got on sale ($25) from newenough.com a while back. They were so good I got a second pair, and recommended them to friends who bought them and were also surprised as to how good (meaning ~warm~) they are!! I don't know about the later year models tho; hopefully they would still be the same way...
