01 ET4
01 ET4
So, I just got my bike back from a paint and body "2 hour tour".
As soon as I go the bike back, I threw in a stebel nautilus.
https://modernvespa.com/forum/topic36338?highlight=
Now I am noticing inconsistencies in my turn signals and high beams and I am unsure if it was the paint and body putting the bike back together wrong OR my wiring of the horn - I highly doubt it is the latter as I did not alter or manipulate the turn signals/high beams at all.
1) the turn signals do not blink at a consistent syncopated rhythm. example; it should be BLINK BLINK BLINK BLINK BLINK. Sometimes I get; BLINK BLINK (PAUSE) SHORTER BLINK BLINK (PAUSE) BLINK SHORTER BLINK. This happens on both left and right, its not a consistent problem (but I feel like it could lead to a bigger problem down the line), and I can't duplicate it to try and isolate the problem.
2) My high beams engage sometimes and then sometimes they do not.
My questions:
What would cause the erratic blinking?
What would cause the highbeams to choose when it wants to go on?
Are the two related?
Did I FARCH something up when installing the horn?
Thanks DUDES and DUDETTES!
2019 VESPA SPRINT 150
Sounds like bad connections on both; most likely from disassembly.
The t/s will flash faster when one of the lamps is not working, either because of bulb or connection. You may want to stand back and watch each t/s bulb to determine which is (are) at fault. That may help you narrow it down.
Switches also seem to be an issue. If it's been sitting for awhile in a dusty environment or gotten paint overspray on the switches, that could be your problem, too. Try cycling the switches several times.
01 ET4
01 ET4
The problem is that its not a "faster" or "slower" situation. Its totally erratic, not a consistent pace, and not constant. It will happen 50% of the time. If it was a constant fast blink, then I know its a dead bulb much like in a car. But all my signals work, the high beams work.
I did 200 miles in a couple days (that's a lot of lefts and rights) and it still seems to be an issue, so I am going to rule this one out, but still keep it in the back of the dormitory.
Any other insight from anyone!?
THANKS!
01 ET4
01 ET4
Ummmmmmm.... ?!
[ Time: 0.0101s ][ Queries: 3 (0.0029s) ][ live ][ 313 ][ ThingOne ]
