@dkrz123 avatar
Honda CTX700N
@dkrz123 avatar
Honda CTX700N
So the rubber weather strip under the seat is loose and keeps slipping out of it's track. Even after I pushed it back in, it still comes out and dangles around when I open the seat. Is it suposed to be glued? Looks to me like it should just snap back onto place... How do I get it to stay put?
Thanks,
dk
@bubbajon avatar
RIP: MP3 500 - Brutto Moto
@bubbajon avatar
Re: rubber weather strip under seat - loose
Thanks,
dk
I had to spot glue mine - same issue. The seal has a "barbed" ridge that snaps into the track. It seemed that it required a bit more pressure than you'd think to snap in. Regardless mine came ;loose again so I spot glued it about every foot.
@luthorhuss avatar
@luthorhuss avatar
What sort of glue did you use?
@bubbajon avatar
@bubbajon avatar
Generic airplane type. Probably what would work best is a weatherstrip adhesive - 3M makes the best - we called it "Gorilla Snot".
10x on the Gorilla Snot
Read directions.
Wayne B
@dkrz123 avatar
Honda CTX700N
@dkrz123 avatar
Honda CTX700N
Gorilla snot it is then. Thanks. You know, this shouldn't really bother me but it does. First the "hose fix" and now this. Really has me questioning the quality of such an expensve machine. I hate these little chicky chock fixes...
When do the plastic side panels start falling off?
Grrrr...
[ Time: 0.0156s ][ Queries: 3 (0.0081s) ][ live ][ 313 ][ ThingOne ]
