@giangrande avatar
Vespa LX 150
@giangrande avatar
Vespa LX 150
Hey Guys-
So last night, in an attempt to make my LX150 stop shuddering on takeoff, I noticed something that wasn't quite right before I started to take a look at the clutch.
First, there was some wear on the engine case and variator, as if the two parts had at some point rubbed together. You can see the variator here: External inline image provided by member with no explanatory text
External inline image provided by member with no explanatory text and the engine case here: External inline image provided by member with no explanatory text
It doesn't look like the problem is too bad, as the scuffing hasn't encompassed the entire surface of the variator, but still... what gives? Has anyone else seen this before? Could this be a source of the shuddering, or is this an entirely different problem that is separate from the glazed clutch?
Thanks!
@zteverhart avatar
06' GTS250ie
@zteverhart avatar
06' GTS250ie
I am no expert but I read this article...i think it may be related. the last thread in the post is the more relevant I think (it references "polishing" off the clutch bell/drum.
https://modernvespa.com/forum/topic5415
you dont want this to happen.
@giangrande avatar
Vespa LX 150
@giangrande avatar
Vespa LX 150
I am definitely looking into the clutch as being the culprit, this was just something tangential I noticed as I was looking over the transmission. Thanks for the reply, though!
[ Time: 0.0119s ][ Queries: 3 (0.0046s) ][ live ][ 313 ][ ThingOne ]
