2013 GTS 300 IE Super (previously 2008 LX 150)
Posts: 163 Location: Sacramento, CA |
I would like to purchase a XEON halogen H4 bulb that is 100w high beam and 90w regular beam. This is more than the stock 65w/55w. With this increase in power draw, will I see noticeable changes and decreases in power and kick?
I don't know Vespa's, does it have a plastic lens or housing? If not you will be fine.
Wayne B |
Unfortunately, I have no clue.
Wayne B wrote: I don't know Vespa's, does it have a plastic lens or housing? If not you will be fine. |
Re: Will a more powerful headlight rob me of power?
luminosity wrote: will I see noticeable changes and decreases in power and kick? |
Posts: 16295 Location: Toronto, Canada, Fort Lauderdale, Florida |
I believe xenon bulbs, although brighter, actually draw less power than the standard halogen bulb. Either way it will not affect the power when you ride your scooter.
Don't do it 90/100w is too hot it will burn your light harness.it would look fine a couple of weeks or so and then presto! ,it happened to my duc
No personal experience, but other MVers have posted pictures of problems, not specifically with the S though, and perhaps a different bulb...
One picture was of a melted lens, another was of a charred harness/connection to bulb. I'll see if I can find the pictures, but they were quite a while ago. cheers |
Quote: No personal experience, but other MVers have posted pictures of problems, not specifically with the S though, and perhaps a different bulb... One picture was of a melted lens, another was of a charred harness/connection to bulb. I'll see if I can find the pictures, but they were quite a while ago. cheers |
Some stories, but no pics that I can find. Have you considered the HID kit from Motorsports? It's supposed to be cool enough.
Look here: http://www.scooterwest.com/item_detail/HID-True-Xenon-Light-Kit/2785/ And a link on MV here; HID headlight cheers |
'10 GTS 300 Super, '79 Vespa P200E, '04 Vespa PX200, 2011 SportCity 300 Cube [Sold]
Posts: 2923 Location: San Francisco, CA |
Here, check this link. Ask Vicferrari - he put one on his LX150.
https://modernvespa.com/forum/topic36734 |
You would be taking a huge chance that you might overload the wiring and start an electrical fire that could cost a bunch of $$$$ to repair..............or worse, you could burn up your scooter. I've read about people doing this on motorcycles (several times) and resulting in an electrical fire. There is a HID headlight kit that several people have installed that apparently works well with no side effects. Whatever you do: Don't just plug a 100 watt bulb in your present socket.
