@tsgraham avatar
'12 Vespa 300 S
@tsgraham avatar
'12 Vespa 300 S
Can anyone tell me if the HID headlight kits available for the GTS are compatible with a modulator?
Kawasaki Z1000, Yamaha R1, Honda SH300i
Very unlikey as HID bulbs take time to warm up
@rocketman avatar
ET2,GT200
@rocketman avatar
ET2,GT200
HID modulators
I want to use a HID kit in my GT 200 and convert the extra running light in the headlight bucket into a halogen ight so I can use my modulator kit. Has anybod tried this or haveany thoughts?
@2011super avatar
2021 GTS 300 Touring
@2011super avatar
I am very happy with my $99 purchase. LINK
@rocketman avatar
ET2,GT200
@rocketman avatar
ET2,GT200
HID Headlight
Thanks for the info , did you have to modify the headlight bucket at all?
@2011super avatar
@2011super avatar
Re: HID Headlight
A very small area needed to be modified and overall the mod was pretty easy according to the Vespa mechanic that did the work. Laughing emoticon
@cary_alburn avatar
LX150
@cary_alburn avatar
LX150
Since modulators do not shut off the light, just reduce its intensity as they "modulate", it shouldn't make any difference. Once the ballast on the HID light is warmed up, it doesn't take any time at all to come to full brightness, and it takes a little time for it to cool down even when shut off completely.
FWIW, I have just recently had installed the aircraft equivalent of a modulator on my little airplane, which has had HID lights for about 4 years--but this actually shuts off power to the lights between flashes. It's called Pulselite by PreciseFlite. My mechanic wired it so that both landing and taxi lights are pulsed 90 pulses per minute (they're beside one another in the left wing). The only recommendation that was made by PreciseFlite is to turn on the lights for about 10 seconds before turning on the Pulselite. I was told that the ballasts for both lights will stay hot enough that there won't be any delay in coming to full brightness. My first night flight with the Pulselite installed was a month ago, and it was easy to tell that the lights came to full brightness immediately after each pulse.
Cary
[ Time: 0.0164s ][ Queries: 3 (0.0074s) ][ live ][ 313 ][ ThingOne ]
