okay..
now the silly question...
can sum1 tell me which one is the
Volatge regulator and the CDI?
is it Voltage regulator is the solid plastic with 3-8 pins, or the one with the metal cooler fins?
i'm miserable in searching the way to fix my bro's et4...
which it all happened when i starts the scoot while holding full the throttle (my bad, i don't know this will ruin my ride since then)...
it's starts... then the ram decreasing till it's like you switched it off... that was the last day the et4 started n dies (about a month ago)...
now, when i switch on the et4;
-headlight and turn signals working..
-the starter working (it tries to start) when i press the elctrc starter button...
-horn r loud as usual...
further check;
-no spark when contacted the spark plug to metal surface (spark plug is in good condition, confirmed)
-no spark at the 2 cables
that connected to the coil (i try to connect each 1 of it to the metal surfaces then start)
n my problem;
-i don't know what i have to do other than changing the Voltage regulator or the CDI.
any recommendations for my problem.. thank you alot guys...
and for your info, i stayed in Malaysia which is very hard to get the piaggio,magneti marelli,etc spare parts... i just can order 'em at superbike service center which is if i ordered wrong.. it can consume alot of my money...
