2020 GTS Notte
2020 GTS Notte
SO my nightmare happened. Sophie, my GT 200 fell on her right side. There is some scuffing on a crack on the brushed aluminum beading that runs along the side, and the paint is scuffed on the rear fender. Anyone know if replacing the beading is something I can do on my own. I have to winterize Sophie anyway, but I thoughT I would make at least one season without something like this. So Depressed! Crying or Very sad emoticon Crying or Very sad emoticon
@zteverhart avatar
06' GTS250ie
@zteverhart avatar
06' GTS250ie
How did you dumb her?
@eek avatar
2005 GT200
@eek avatar
2005 GT200
I did my own beading. Took a minute but as soon as I figured out I had to separate the floor board, glove box and legshield from each other it was a breeze.
I tried to have the Vespa dealer do this work for me but they couldn't figure out how to attach the beading. Just have some patience and you will be happy and proud when its done.
Good luck...
@saladgirl avatar
Vespa 200GT
@saladgirl avatar
Vespa 200GT
bummer...
you might want to buy some real crash bars, they give more protection. I am looking into it myself after a fellow rider told me she dropped her bike(fully kitted out with sturdy crashbars front and rear)and no damage except a little scrape to her mirror. Repairs on a dented cowl are around $1,000 someone told me. Way cheaper to get the bars, and it ups the cool factor;) Sally
2020 GTS Notte
2020 GTS Notte
Thanks for the advice.
Thanks for sharing your nsights guys!
I dumped my GT200 in the garage. Of all places. It just started falling to one side and I guess the momentum got the best of me. I didn't dent the cowl, just scratched the paint.
AS for the beading, it doesn't sound hard. The dealer said it would be an hour worth of service plus part ($100).
Are there places you can just order the beading from?
@boulty avatar
Moderator Australis
2014 Moto Guzzi V7 Stone, 2014 Vespa 150 Primavera (sold) 2003 Vespa GT200 (sold)
Moderator Australis
@boulty avatar
Sorry to ear of your plight. My kids tipped over my GT200 and I got away with a fingernail size scratch, but more importantly two uninjured daughters. The 135kg can easily get away on you once it has momentum. If there is a bright side, I was just reading the review of the new Honda Goldwing with more bling. Now tops out at 425kg imagine trying to stop that tipping over!
Good luck patching her up.
@redxluckyxcharms avatar
2009 Siena Ivory GTV 250ie "Sasha"
Re: bummer...
maybe I am misunderstanding you, but I scratched my cowl and I got a replacement for $116 from the dealer. after they installed it, it came to like $130.
@saladgirl avatar
Vespa 200GT
@saladgirl avatar
Vespa 200GT
Cowl replacement
I was quoting what someone else told me cowls cost...I really don't know myself. I think your dealer may have cut you a good deal though:) Sally
2007 GTS250ie Silver, 2008 Vespa S White (deceased)
The cowl is not replaceable. It is the bulk of the body. You need to have it banged out and repainted and that is not cheap, especially if it is the right because then you have to remove the gas tank which right under the right cowl. The leg shield beading is not easy to replace. Follow the instructions in the technical library for removing the glove box and then remove the lower part of the cowl that is plastic and then remove the screws for the floorboard on that side so that you can lift it up to install the beading. It is pretty finicky stuff so good luck.
@jcanavera avatar
GTS250
@jcanavera avatar
GTS250
I dropped my 250 on its side in the garage. Trying to tip it to one side to shake out a screw that I dropped (a whole other story). It fell on top of one of those big 6 volt battery flashlights. Dented in the cowl on the gas tank side. I took it to a dent removal place that pulled out the dent. Thankfully the flashlight was plastic and no paint was damaged. It was the first time the place had ever worked on a Vespa (they've done lots of Harley fenders though). Cost was $150 and its undetectable. I wish I had taken a before picture because it's quite remarkable how well the repair went.
Jack
@eek avatar
2005 GT200
@eek avatar
2005 GT200
I think what was scratched is the lower plastic part of the cowl that can be replaced, and replacing the beading is quite simple... No need to pay over priced labor charges from any shop to replace your beading...
@apdx avatar
Vespa T5, Vespa P200E
@apdx avatar
time to paint it flat black.
@sibertater avatar
@sibertater avatar
Re: Cowl replacement
If his dealer and my dealer are the same, there are no deals. Just cash...and they work out of the back of a van....but seriously, folks...they're not cheap.
@el_josh_aka_ruby avatar
GTS 250ie
GTS 250ie
+1
well Maybe I am wrong, what would this part be called then?
the part below the vespa logo... isn't that a cowl?
@jrsjr avatar
Nazgul
@jrsjr avatar
Nazgul
You're in luck. What you've damaged is a plastic trim piece that is attached to the metal cowl. If your dealer can obtain the piece, it will take them about five minutes to swap it out.
P.S. It is a scientifically established fact that Modern Vespas accelerate faster, handle better, and stop harder better once they have their first ding.
Thats not his. I was just explaining the part that I got for $116 and I was told it was called a cowl, but I guess I'm wrong.
@jrsjr avatar
Nazgul
@jrsjr avatar
Nazgul
I'm sorry. I misunderstood.
haha It's ok! I think I'm a little confused too. haha no worries!
[ Time: 0.0217s ][ Queries: 3 (0.0090s) ][ live ][ 313 ][ ThingOne ]
