Sun, 26 Oct 2008 14:15:29 +0000
Sun, 26 Oct 2008 14:15:29 +0000 quote
Installed Cosa cluth in P200E. Polted everything back together, then noticed that my flywheel was jammed. Thought all kinds of things. Fist though that the spacer washer was too thick. I shved about 01.2mm off of it. Bolted the ride back together, same problem. Flywheel not turning. zchecked the Cosa bolt. Not using casa wavy washer.I just boled it on, 30lb on the nut. Everything checked out okay. Put the clutch cover back on, flywheel still not turning. Then it dawned on me that the fly lock issue is a result ofthe Cosa clutch rubbing on the clutch cover when its on. I went ahead and shaved some material from the insde of the cover. The web pattern support inside I took downa bit as i assumed that it may be rubbing. Yet, the ccrank still does not rotate. Any advice would be appreciated. Doe I need to obtain another clutch cover? This is a old P200. Is there a PX/Cosa cover out there that I should be looking at?
Also the spacewasher, should I still run that despite me shaving off a mm worh of material?
Sun, 26 Oct 2008 16:50:40 +0000
Sun, 26 Oct 2008 16:50:40 +0000 quote
Okay
I grounded a lot of Aluminum away and I think I sorted the probs out. The channel in the hub cover was rubbing it the wrong way. Not in a good way like a cute girl. Anyhow I think its sorted.
Fell free to add more if I have over looked something.
Sun, 26 Oct 2008 17:18:41 +0000
Sun, 26 Oct 2008 17:18:41 +0000 quote
Back to square one
I put the pressure plate on. Now the clutch rubs again. Cant really grind away any more material. And the clutch washer is very thin. Does any one know where I may get a Casa/Px clutch cover that's tall enough for the cosa clutch but the same diameter to fit a Mk1 p200?
Sun, 26 Oct 2008 20:47:00 +0000
Vespa GTS300ie
Vespa GTS300ie
Sun, 26 Oct 2008 20:47:00 +0000 quote
why don't you leave it alone and fit the standard clutch in
Sun, 26 Oct 2008 20:55:20 +0000
GTS 250ie, Triumph Speed Triple
Sun, 26 Oct 2008 20:55:20 +0000 quote
Because Cosa is easier to use.
Sun, 26 Oct 2008 21:29:03 +0000
Vespa GTS300ie
Vespa GTS300ie
Sun, 26 Oct 2008 21:29:03 +0000 quote
not when it don't work and you grind half the engine away
Mon, 27 Oct 2008 01:48:28 +0000
Mon, 27 Oct 2008 01:48:28 +0000 quote
I think the guys on the BBS have it right - your thrust washer is screwing you up.
Rock a smaller thrust washer behind the clutch and it will work.
Mon, 27 Oct 2008 03:47:12 +0000
Mon, 27 Oct 2008 03:47:12 +0000 quote
I've got the washer at 1.5mm already. Any thinner and it would be useless t o even use it. Someone said on BBS that it should fit despite the cover. However, I have the clutch all of the way down on the crank. Wont go any farther. Dont know what to do at this point. Stumped
Mon, 27 Oct 2008 12:51:30 +0000
Mon, 27 Oct 2008 12:51:30 +0000 quote
Pull the thrust washer and try again. Try it without it.
( my opinion - it's worth seeing if it fits without one on there at all. I've ridden bikes without thrust washers on there, and though some folks will swear you NEED one or else the clutch will snatch more often, others - like me, will tell you how they've ridden without one for quite some time )
Tue, 28 Oct 2008 08:34:58 +0000
Tue, 28 Oct 2008 08:34:58 +0000 quote
Cheers man.
It fits without it. Problem was the woodruff key. Too wide and too tall. I have to shave it down just a little. I hope all will be okay. There was some side to side play before I tightened it. I put about 30+ lbs on the nut. No more play. Will test it soon.
  DoubleGood Design
[ Time: 0.0279s ][ Queries: 3 (0.0065s) ][ Debug on ][ 298 ][ Thing Two ]
