LX150
LX150
I have a 2006 LX150. My right mirror vibrates and makes an awful rattle noise. The rattling is louder than the scooter. The sound goes away when I'm in motion but returns when I'm stopped with the motor running? The mirror is fine otherwise.
Can I open the mirror somehow to stabilize it?
my vespa
my vespa
@masala avatar
@masala avatar
946
I haven't done it personally, but you can remove the mirror from the chrome backing (plastic ring?). Behind the mirror you will find a nut which can be tightened, and hopefully that will solve your problem!
Best of luck!
@paperino avatar
GTS 250 "Audrey"
@paperino avatar
GTS 250 "Audrey"
Sorry bunnyman, I'm no help. But I just read ChipH's post on proper riding attire, and then saw your post on vibrating mirrors, well your photo is not what came to mind. Okay, now I'm back to a scooter frame of mind.
@harvey avatar
@harvey avatar
Is it the mirror base that's loose?
If it is you can undo the allen screw on the front the plastic housing the mirror mounts into, pull the housing up and tighten the locking nut underneath.
Or is the mirror loose on it's stalk?
Try this (or get the dealer to fix it!)
https://modernvespa.com/forum/topic18781?highlight=mirror#248861
Regards
Harvey
@big_foot avatar
Scooterless at the moment
@big_foot avatar
I had an LX150 before and the mirror itself would rotate inside the mirror housing,
Not sure how it can be fixed, But that topic has been brought up here before.
I think the cure was to take it into the dealer and get them to fix it
or replace it under warranty.
LX150
LX150
It's not a good vibration Paperino. (-:
It is the mirror itself that is loose. The stem is fine. The mirror buzzes inside the chrome casing.
How would I get behind the mirror?
Thanks for all the help!
sonny
@harvey avatar
@harvey avatar
@scooterdoodle avatar
2006 Vespa LX150,1978 Lambretta Jet
I had the same rattling and found it was not the bolt on the stem shaft, it was the plastic piece attached to the rear of the mirror.Be very careful if you attempt to remove the mirror from the stem though.
I removed the mirror per the post that was linked previously. However I messed up, there was a suggestion to "heat up" the rubber ring that surrounds the mirror in warm water and I managed to melt it a bit. And wasn't able to mount it back on the stem.
Until I get around to replace my mirror it looks so classy sporting duct tape trim. On the upside the rattle is gone
LX150
LX150
Thanks again!
I'll try this today. Thanks a ton!
sonny
@avatarcourt avatar
Vespa LX 150
@avatarcourt avatar
Vespa LX 150
Somewhat similar mirror issue
I've got mirror trouble too. The entire stem appears to be loose. The problem goes deeper than the nut that's located inside the rubber housing. It doesn't rotate like if that nut was loose, instead the entire stem can move approximately half a centimeter back and forth. Especially noticeable at an idle. Anyone know how I can get in there and tighten it? The right mirror stem is tighter than my waistband after Christmas dinner.
@harvey avatar
@harvey avatar
I would think that yours is just very loose. Try screwing in the stem. If it makes solid contact, adjust it using the advice from the previous threads. If you've stripped the threads (not easy to do) it's time to talk to your dealer/mechanic.
Regards
Harvey
@quattrovalvole avatar
09 GTS300 Super black, 04 GT 200 smoky, 05 GT 125 smoky (in pieces)
Re: Somewhat similar mirror issue
You need to tighten the allen head bolt on the mounting hardware on the handlebar. Unfortunately, you must remove the headset to do this. If you haven't done it before, do a search in the forum for threads on removing the headset or check the DIY reference section, where I believe Jess posted a thread with pics.
Put all the screws you remove in a ziplock bag for safe keeping until reassembly. Good luck, and Happy New Year!
@michaelr avatar
2006 GT 200, 2007 BV 500
@michaelr avatar
Go to this posting and check it out.
Regards
Harvey
@drewteague avatar
@drewteague avatar
This fix is correct only if your brake handle is moving along with the mirror. If so, the bracket is designed for tightening without the removal of the headset. Once the mirror is removed, look in the hole with a flashlight, and you will see a cutaway that leads to an Allen screw. It is slightly off center, so a ball-head is necessary.
If the brake handle is tight but the mirror is still loose, then the mirror is either very loose in the base, or has stripped the aluminum threads altogether.
@harvey avatar
@harvey avatar
The original post is from 2008.
[ Time: 0.0221s ][ Queries: 4 (0.0145s) ][ live ][ 313 ][ ThingOne ]
