@mike_lynch avatar
Aprilia Scarabeo 500 (Heavy)
@mike_lynch avatar
FYI
It all seems so simple now.
I saw this video and I really need to give it some consideration.
http://www.youtube.com/watch?v=fBHAM1am-UE
If this will work on a GT-200 and or an S-500 - life will be very good.
Best regards,
Mike Lynch
@got_mine avatar
@got_mine avatar
He must either have weak spings in there or he has been doing some exercises to strengthen his hands..
I had troubles squeezing mine only half that compressed...
@greasy125 avatar
@greasy125 avatar
it's a 50... hence, the easy compression on the contra spring.
best,
-greasy
@jerryg avatar
2005 Dragon Red Vespa ET4 Speedster
@jerryg avatar
Greasy, what are you doing up at this hour??
@greasy125 avatar
@greasy125 avatar
just getting home from the shop. unwinding, answering emails, putting together parts orders and call lists for tomorrow...
really... it's not that unreasonable of an hour...
best,
-greasy
@joel_hamilton avatar
'07 GTS (RIP) '09 GTS Ducati M750
best,
-greasy
Glad you noticed that. I wrestled with the clutch on the 250 by the side of the road... thankfully rolf showed me how to use a pizza box or something to cover the impeller blades on that thing... youch..
it isnt that tough once you get the feel for the cam action of the clutch: the twist and pull.
@glasseye avatar
@glasseye avatar
15 minute job....in the dark.....in a motel parking lot....been there done that...
Easy once you've done it a few times.
A folded shop towel works great on the torque driver.
R
8)
@jk_single avatar
Vespa P200E, Fly 50, Vespa S50, Vespa GTS 300
@jk_single avatar
Re: Yikes! A very fast / easy CVT Belt replacement!
This won't work on an S-500 or any other Master equipped scooter. The clutch and vari are inside the casing so you have to dismount them both to be able to remove the belt + you need real tools due to high tightening torques.
0:7 And counting
0:7 And counting
+1. You can't do it that way on any modern Vespa engine. You have to remove the clutch and the variator.
[ Time: 0.0096s ][ Queries: 3 (0.0016s) ][ live ][ 313 ][ ThingOne ]
