Hi, jimc, got the copperslip from Comma but it says 'Copper Ease' but when I saw the 'anti-seize assembly compound', I was sure that it was it. The applications for it is a lot. From protecting battery terminals to engine gaskets to the threads of spark plugs and nuts bolts, steering and suspensions, universal joints, and exhaust system. Remember that you recommended the copperslip to the shaft that is holding the rear wheel in my previous posting. As the rear tire have been changed just a short while ago, should i just wait for the next tire change to apply the copperslip? Without the proper tools I found it quite truoblesome to take things apart for just the application to just the shaft. Should I wait? Thanks in advance for any advice received. Cheers!
