Thu, 30 Oct 2008 15:40:23 +0000
3 Lammy's & 1 Vethpa
Thu, 30 Oct 2008 15:40:23 +0000 quote
Hi all..I need some help.
The tube that the rear brake cable goes in to is in BAD shape. Rusted out..part of the cable is stuck inside...and ain't coming out.
Is this part replaceable? Any suggestions for a fix?...(other than "just use the front brake"..."buy shoes with thick soles")
And no....I did not cut the floorboard out to take the picture!
Glenn
Thu, 30 Oct 2008 18:10:05 +0000
Blue 70th anniversary Vespa GTS 300
Thu, 30 Oct 2008 18:10:05 +0000 quote
Spray it with WD 40 laeve it for a while then try to release it, if not keep spraying
Thu, 30 Oct 2008 18:13:39 +0000
Thu, 30 Oct 2008 18:13:39 +0000 quote
does that tube(?) come out?
or is that a part of the frame?
Thanx
Thu, 30 Oct 2008 18:37:23 +0000
Thu, 30 Oct 2008 18:37:23 +0000 quote
That I don't know, in the second photo it looks like the outer cable,( hence the answer about WD 40) but in the top photo it looks as if it should be there and the inner cable is fed through it to connect with the pedal. If that is the case then it probably explains why it will not move
Thu, 30 Oct 2008 19:36:16 +0000
Thu, 30 Oct 2008 19:36:16 +0000 quote
My concern is that it's part of the frame. The end of the old cable is rusted into the tube itself. I have looked at pics of new cables...and that part does not appear to be a part of the cable assembly....and I can't find it on any parts diagram. I may have to manufacture something....hoping somebody has encountered this before and can give me some direction.
Thu, 30 Oct 2008 19:41:26 +0000
Sponsor
DL200, TV2, Vega, Lui, GTS
Sponsor
Thu, 30 Oct 2008 19:41:26 +0000 quote
Its part of the frame.
You'll have to cut it off and have something made, machined to fit correctly, to replace it. Or find a crapped out donor frame, see if that piece is useable, cut it off and weld it on.
The bit in the bottom pic is what stops the cable. Doesn't look the worst I've seen. Test it with a cable before you cut it off. It might be useable.
Andrea
Thu, 30 Oct 2008 19:48:56 +0000
I have a few scooters....
Thu, 30 Oct 2008 19:48:56 +0000 quote
I had a similar situation with the choke cable on my Allstate. I used a close fitting drill bit and spun it in the tube. It caught the coil of the cable outer. I kept at it until I was able to grab the coil of the cable outer with some pliers. It's like stretching out a spring. At least your floor is already open to give you some access.
Thu, 30 Oct 2008 19:49:51 +0000
Thu, 30 Oct 2008 19:49:51 +0000 quote
If the old cable has rusted into it then again spray it with WD 40 or a realeasing spray then try pushing it out with the end of a new cable. If it's badly rusted in the keep applying the spray ( leave it to work for a while first though) and keep trying
Thu, 30 Oct 2008 19:56:00 +0000
Sponsor
Sponsor
Thu, 30 Oct 2008 19:56:00 +0000 quote
WD40 is crap to release seized things. Try PB Blaster or a penetrating oil.
The WD stands for Water displacement. Its not real good at penetrating things.
Andrea
Thu, 30 Oct 2008 20:02:42 +0000
Thu, 30 Oct 2008 20:02:42 +0000 quote
Thanks everybody....I was hoping it would be as simple as just buying a new piece...oh well.
I think I'll just close the garage door for the rest of the day.
Andrea.....I'll be calling you soon with my parts order.
Scooters Originali comes VERY highly recommended by everyone I have talked to here in the Detroit/Windsor area.
Thanks again everyone
Glenn
Thu, 30 Oct 2008 20:15:04 +0000
Thu, 30 Oct 2008 20:15:04 +0000 quote
can't leave it alone...
how far inside does the cable casing go?
Is the inside diameter of the tube the same all the way through? and then just a smaller opening at the end to allow just the cable through?
I hope I explained that right.
Thu, 30 Oct 2008 20:26:09 +0000
Sponsor
Sponsor
Thu, 30 Oct 2008 20:26:09 +0000 quote
It has actually occurred to me that the bit that you've been trying to release is actually the cable stop but I didn't really think you'd be trying to get that out.
The outer tube is one piece. The complete cable goes inside and then the narrower inner part in the tube stops the outer cable from moving any further, just allowing the inner to move to activate the brake.
Andrea
Thu, 30 Oct 2008 20:45:23 +0000
Thu, 30 Oct 2008 20:45:23 +0000 quote
Think of that piece as shaped like a test tube with a small hole in the bottom. Only the cable inner should be able to go all the way through. The cable outer should slide from the rear of the scooter all the way up to the point where the small hole allows the inner to come through. I hope that makes sense.
Thu, 30 Oct 2008 21:47:04 +0000
Thu, 30 Oct 2008 21:47:04 +0000 quote
Thanks Killo....just got off the phone with Scooters Originali and got the scoop on the mechanics of it. If I can't get the tube cleaned out, or if it isn't salvageable, I have an old push rod (out of something) that may be the right size...as long as the ID is correct...it should work.
Thu, 30 Oct 2008 22:35:22 +0000
Thu, 30 Oct 2008 22:35:22 +0000 quote
You just gotta love Scooters Originali...they always seem to be there when ya need them!
Thu, 30 Oct 2008 22:40:06 +0000
64 Vespa 150cc
64 Vespa 150cc
Thu, 30 Oct 2008 22:40:06 +0000 quote
Heat is your freind when it comes to rust. You probably dont have an oxy/acetalane torch(which may be overkill anyway) however you can go to the hardware store and buy a propane plumbers torch and heat that baby up. That torch does not get hot enough to melt what you have there. Try and get it red hot and have some type of metal rod to poke out the stuck piece-make sure you are wearing some thick leather work gloves and have a spray bottle of water by your side for safety, while performing this.
  DoubleGood Design
[ Time: 0.0346s ][ Queries: 4 (0.0127s) ][ Debug on ][ 298 ][ Thing Two ]
