Fri, 31 Oct 2008 04:31:35 +0000
'78 Super 150 Mk II ported DR177, banded clutch, ASC Big Bore
Fri, 31 Oct 2008 04:31:35 +0000 quote
I'm wondering what tire pressures people generally run on vintage Vespas. I've got a 1978 Super 150 (Mk II Eurospec) that has 8" tires (with tubes, obviously). The original manual says to run 15.5 PSI front, 18.5 PSI rear with one rider, or 32.7 - 35.5 PSI with two.
Those single rider figures seem way too low to me. We've recently had some quite cold temps here (below freezing at night) so naturally tire pressures have dropped; on a short test drive they felt quite squirmy so I knew a refill was a must. After pumping them up, I thought even 20 PSI front and 25 or so rear seemed somehwhat low compared to what I had run comfortably on in the summer (I've got Michelin S83s 3.5x8).
I know tire compounds have changes drastically since the 70s when the manual was produced, might innertubes have also changes and different pressures are suitable now? What do others use -- I'm particularly interested in responses by those with 8" tires as well.
On another note, it's been more than usually difficult to fill up the rear tire: the valve stem end is so close to the hub (it bends over the split rim half) that I can't even fit a pump onto it without removing the wheel entirely off the hub first. I might switch front and rear over the winter and see if it makes access easier.
Cheers.
phaetn
Fri, 31 Oct 2008 09:31:03 +0000
Fri, 31 Oct 2008 09:31:03 +0000 quote
Funny thing you should mention!
I always was a bit perplexed with the rear tire solo pressure being so much lower than with pillion. For totally non-scientific reasons, I've used a higher solo pressure of about 25% of the difference between the two - about 24 psi.
Can't say if it is good, bad or no difference, but it made me feel good!
Al
Fri, 31 Oct 2008 14:32:59 +0000
SawStop
SawStop
Fri, 31 Oct 2008 14:32:59 +0000 quote
There is a great article in this month's scootering magazine about tire ratings, and a fair amount of time is spent on tire pressure. Maintaining the proper tire pressure for the load on the tire is important, because an improperly inflated tire at high speeds creates more heat. Too much heat will begin to affect the integrity of the tire and possibly even the tube.
It's a pretty thorough article, and well worth the cost of the magazine. I found a copy at Barnes and Noble last evening.
Fri, 31 Oct 2008 17:42:27 +0000
Fri, 31 Oct 2008 17:42:27 +0000 quote
Len-
Unfortunatlely, Scootering is not available here.
However, over the years, I have read numerous articles and tech bulletins about tires and inflation. Interestingly enough, just about any under inflation is a more serious threat to a tire than slight over inflation.
Tires are manufactured to meet max load, road speed (RPM) and inflation pressure. These are based on the structural limits of the tire. HOWEVER, the inflation pressure for a given tire on a given vehicle is determined by the vehicle manufacturer, based on a variety of factors, mostly pertaining to ride feel and handling characteristics desired.
Inflating below the vehicle manufacturer's recommended pressure will cause the tire to run "fattened and flattened" putting undue stress on the tire body, causing heat build up, reducing tire/tread life and fuel economy and causes poor handling if the pressure is low enough.
Inflating above the vehicle manufacturer's recommended tire pressure, but below the tire manufacturer's max pressure tends to effect the quality of the ride (harder and harder) and the tire's response to bumps and holes in the road. It does not, however, threaten the tire integrity. You will note in the links below that it is common for racers to "over inflate" their tires for improved handling.
Check these two sites
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=1
http://www.betiresmart.ca/inflation/proper.asp?loc1=inflation&loc2=proper
In the main, inflating to the vehicle manufacturer's specified pressure is a wise bet. A little over inflation can be done to your taste.
Al
Fri, 31 Oct 2008 19:13:21 +0000
Vespa 50 Special '71 / Vespa 150 Sprint V '78
Fri, 31 Oct 2008 19:13:21 +0000 quote
Al
Yup...on my race bicylce I over inflated up to a (nice value) 123 PSI in metric 8.5 Bar
As I find my Heidenau tyres a bit bumpy, I under inflate these to 29 PSÏ (2 Bar) front / 32 PSI (2.2 Bar) back.
Fri, 31 Oct 2008 19:54:22 +0000
90ss, et3
90ss, et3
Fri, 31 Oct 2008 19:54:22 +0000 quote
I generally run 27 front, 32 rear for solo. And double, as the girlfriend weighs nothing.
Fri, 31 Oct 2008 20:27:17 +0000
Fri, 31 Oct 2008 20:27:17 +0000 quote
Thanks for all the replies, gents.
Tonysmallframe, I'm at about that range myself (though in a largeframe with a 150cc engine, so it certainly weighs more). I won't make any comment about my wife so I can actually keep my Vespa.
I'll definitely see if I can get my hands on a copy of the latest Scootering magazine. Given that we use innertubes, and that we actually lean on the tires for cornering, unlike cars, I wonder what other issues might arise apart from those already listed in those two helpful links, Aviator. I used to race cars and know about the importance of pressure, and the varying grip and performance it offers, but I'm relatively new to two wheeling.
Cheers,
phaetn
Fri, 31 Oct 2008 21:00:11 +0000
Fri, 31 Oct 2008 21:00:11 +0000 quote
I run about 20psi front, and 30 psi rear.... on all my bikes.
Sat, 01 Nov 2008 00:21:57 +0000
21 75th Anniv. Primavera, 10 GTS Super 300, 64 Allstate, 61 VNB, 61 GL, 61 Lammy LI 125 Mahi Shriner, 57 Lammy LD125
Location: Baltimore-Washington-Asbury Park at the Jersey Shore
Sat, 01 Nov 2008 00:21:57 +0000 quote
For those of you who don't know them, Tony and his girlfriend TOGETHER still weigh nothing.
And Happy Birthday, Eric!
Sat, 01 Nov 2008 02:43:53 +0000
SawStop
SawStop
Sat, 01 Nov 2008 02:43:53 +0000 quote
Continental recommends against under-inflating tires in order to get a softer ride. Here's what they have to say:
"We do however advise that you always ride at the highest pressure level given in the manual. Some amount of comfort will be lost, but that loss will be outweighed by improved safety. In addition the rolling resistance will be lower which will help to save fuel."
Sun, 02 Nov 2008 00:16:44 +0000
over 60 scooter spanning 75 years
Sun, 02 Nov 2008 00:16:44 +0000 quote
22psi on the front and 37psi on the rear more air in the back because of the weight of the engine and well if the roads are good have more in the front too
if the roads suck have less this gives you much more bounce for ruff ride
Sun, 02 Nov 2008 00:17:11 +0000
Sun, 02 Nov 2008 00:17:11 +0000 quote
Sun, 02 Nov 2008 03:01:16 +0000
Stella
Stella
Sun, 02 Nov 2008 03:01:16 +0000 quote
Does it make a difference if they are 8" or 10"?
  DoubleGood Design
[ Time: 0.0465s ][ Queries: 3 (0.0259s) ][ Debug on ][ 298 ][ Thing Two ]
