Timbit wrote:
Based on the description, that is not a simple momentary switch. Or perhaps it is and you are paying for the relay setup as well.
It does look cool though and might be available cheaper at an electronics dealer.
You can buy just the switch for $30 or whatever. Granted thats a lot of money for ONE switch, but I am going to have a few and I think aesthetically it will end up being RAD!
touchton wrote:
It looks like the momentary switch is what you would want. I don't see any specific documentation that shows how the switch/light is wired, but you can make it work. If the light and switch are seperate, your golden. Run the light off the scotter power (12v) and use the dry contacts to operate the GDO (9v). On the other hand, if it's integrated it can still be done. Drive the GDO with 12v (eliminating the GDO battery) or use the switch to drive a relay that drives the GDO. There's a dozen ways to skin this cat. Just depends on how bad you want that shinny light.
Personally, I like the idea of driving the GDO with the scooter's switched 12v. This way you have to have the key and turn the scooter on the operate the door.
The light and switch are separate. I agree with you, wiring to the switched 12v is a better idea. This dummy (me) might be getting in over his head. We'll see. If anyone knows of a thread or link that tells you how to power the GDO to a switched 12v, PLEASE feel free to post it here.
Thank you ALL
