Fri, 31 Oct 2008 15:34:40 +0000
1976 Rally 200
Posts: 11 Location: Raleigh |
1976 Rally 200
I have a '76 rally 200 and need to replace the steering column lock. I do not have the original key. What's the trick to removing the cylinder, I have a replacement ordered from Scooterworks.
![]() Current: 1976 150 Sprint V Previous: VS5 GS 150, 1974 Rally 200, 2005 GT 200
Posts: 1946 Location: Oakland. 1000 posts, only 10 of any value |
Fri, 31 Oct 2008 15:51:50 +0000
There may be a better trick, but I've just drilled through the old one.
Fri, 31 Oct 2008 15:55:34 +0000
1976 Rally 200
1976 Rally 200
Steering column lock replacement
cipote wrote: There may be a better trick, but I've just drilled through the old one. |
![]() Fri, 31 Oct 2008 16:11:05 +0000
'76 Rally
Posts: 94 Location: Chicago |
![]() '76 Rally
crb, let us know how it goes.
I'm in the middle of a '76 rally rebuild and was wondering what to do with the column lock as well. |
![]() Fri, 31 Oct 2008 16:16:18 +0000
2007 GT200 1979 P200E 1980 P200E 2011 Triumph America
Posts: 1265 Location: Sacramento |
![]() 2007 GT200 1979 P200E 1980 P200E 2011 Triumph America
Try this step by step tutorial:
http://www.scooterhelp.com/tips/body/70s.locks.html ⚠️ Last edited by SteveinSac on Fri, 31 Oct 2008 16:57:23 +0000; edited 1 time
Fri, 31 Oct 2008 16:16:37 +0000
1976 Rally 200
1976 Rally 200
the deacon wrote: crb, let us know how it goes. I'm in the middle of a '76 rally rebuild and was wondering what to do with the column lock as well. |
Fri, 31 Oct 2008 16:19:15 +0000
1976 Rally 200
1976 Rally 200
SteveinSac wrote: Try this step by step tuturial: http://www.scooterhelp.com/tips/body/70s.locks.html |
Fri, 31 Oct 2008 16:25:21 +0000
1976 Rally 200
1976 Rally 200
![]() Mon, 03 Nov 2008 21:12:34 +0000
'76 Rally
![]() '76 Rally
Mon, 03 Nov 2008 21:21:57 +0000
1976 Rally 200
1976 Rally 200
the deacon wrote: got it, thanks did you replace yours yet? |
Tue, 04 Nov 2008 18:24:00 +0000
Please keep us posted on how it goes, especially if you come across any tips. I'll be doing mine over the winter, and was planning on using the method linked above.
Mon, 17 Nov 2008 15:34:15 +0000
1976 Rally 200
1976 Rally 200
Mon, 17 Nov 2008 16:10:48 +0000
Posts: 14 Location: Canada |
Isn't an easier solution to just have a key made to replace the missing key and not deal with replacing the whole lock? I've wondered about this for a while now since I hear so much about people replacing the locks over missing keys.
Mon, 17 Nov 2008 16:22:46 +0000
1976 Rally 200
1976 Rally 200
vintagewasp wrote: Isn't an easier solution to just have a key made to replace the missing key and not deal with replacing the whole lock? I've wondered about this for a while now since I hear so much about people replacing the locks over missing keys. http://www.scooterwest.com/item/Vintage-Locks/167/ Still, I bought the steering lock and glovebox lock set for $35.00. I'm sure a locksmith would charge more to cut a key. Seriously, it took about 15 minutes to install a fresh new sterring and glovebox set. |
Mon, 17 Nov 2008 16:45:08 +0000
![]() Mon, 17 Nov 2008 17:25:02 +0000
'76 Rally
![]() '76 Rally
thanks for the update CRB. Seems like a snap. I'm having trouble just removing the pin for the cover plate. Will try and hit it with a little heat this weekend.
Mon, 17 Nov 2008 17:52:34 +0000
1976 Rally 200
1976 Rally 200
the deacon wrote: thanks for the update CRB. Seems like a snap. I'm having trouble just removing the pin for the cover plate. Will try and hit it with a little heat this weekend. |
