2005 Px150
2005 Px150
Hey guys i ran out of oil for my px150 and I need to get some locally today, what type of oil would be suitable? Thanks in advance!
@coley avatar
'83 PX125E (little Red) / '09 Fuoco (unnamed)
@coley avatar
Get a decent 2T / 2 stroke oil. In my kitted PX I use Amsoil Dominator synthetic.
Opinions on 2T oil vary greatly... so you're bound to get a ton of opinions.
Check out this link: http://forums.stellaspeed.com/viewtopic.php?f=14&t=1134
If you're changing out the rear gear box oil - look for the cheapest non-detergent 30 weight oil you can find. It's not as picky if you change it often.
2005 Px150
2005 Px150
just to clarify, i am talking about the oil that mixes with the gas, but it goes into the reservoir next to the gas tank
@chad avatar
Olivia Newton-John
p200, vbb, gt200, px150, vnb
Olivia Newton-John
@chad avatar
i use synthetic 2t, amsoil interceptor. as long as it's 2t and is designed for motorcycles, it doesn't really matter. i just use ams because all of the gas stations here have it.
@sarah avatar
Stella
@sarah avatar
Stella
I also use Amsoil Interceptor.
@valimagdon avatar
'80 Bajaj Chetak; '65 Vespa V90; '59 Lambretta Li125
@valimagdon avatar
The kind of oil that uses the SEARCH function first...
Any semi-synthetic or full-synthetic oil is absolutely just fine to use. If you have a super tuned machine (which I'm guessing you don't) then you should start worrying about the fancy oils. Heck, even the regular dino 2T oil will work just fine in a pinch. (not that it wouldn't work just fine all the time, but the syn and semi-syn are better for the long-term life of the engine) You don't have to spend $12 a liter if you don't want to!
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
piaggio state * fully sythetic 2-stroke oil for your px *
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Mobil fully synthetic 2T oil. Cost-efficient and seems very clean.
@valimagdon avatar
@valimagdon avatar
That's kind of like any car/motorcycle/scooter/any other machine's owner's manual telling you to "use only the most highest premium super-expensive oils or else we can't be liable if you blow up your vehicle ha ha ha"
Piaggio also recommends only using Selenia brand 2T oil. Does anyone here actually use that? How many shops actually carry that?
[ Time: 0.0091s ][ Queries: 3 (0.0032s) ][ live ][ 313 ][ ThingOne ]
