Some one was just telling me not to believe everything i read on the net
cant remeber where i got htis info but here it is
Technical Specification - PX 125;
Engine - 2 stroke, single cylinder
Displacement - 123.4 cc
Bore - 52.5 mm
Stroke - 57 mm
Fuel - Unleaded petrol N.O.R. min. 95
Induction - Rotating valve in crankcase
Ignition - Electronic CDI
Starter - Electric and kick starter
Lubrication - Separate with automatic oil pump
Cooling - Forced air
Gear change - Manual, 4 speed
Clutch - Oil wet clutch
Frame - Pressed steel monocoque
Front suspension - Oscillating arm with helicoidal spring and hydraulic double effect single damper
Rear suspension - Engine works as oscillating arm, double effect damper
Front brake - Hydraulic with Ø 200 mm stainless steel disc
Rear brake - Ø 150 mm drum, mechanically commanded
Front wheel rim - Pressed steel rim 2.10 - 10"
Rear wheel rim - Pressed steel rim 2.10 - 10"
Front tyre - Tube type 3.50 - 10"
Rear tyre - Tube type 3.50 - 10"
Length - 1,810 mm
Width - 740 mm
Wheel base - 1,260 mm
Saddle height - 810 mm
Dry weight - 97 kg
Fuel tank capacity - 8 litres
Power - CV 9 (Kw 6.6) at 6,000 rpm
Maximum speed - 90 Km/hour
Lubricant Tank Capacity - 1,5 litres
Technical Specification - PX 150;
Engine - Single cylinder catalysed two stroke
Displacement - 151 cc
Bore - 57 mm
Stroke - 58 mm
Induction - Rotating valve in crakcase
Power - 8.2 CV
Start - Electric and kick starter
Lubrication - Automatic oil-fuel mixer
Gear change - Four speed, on handlebar
Front suspension - Oscillating arm, coil spring and dual effect hydraulic shock absorber
Rear suspension - Hydraulic shock absorber, 88 mm stroke
Front brake - Ø 200 mm disc, calliper with two opposed pistons
Wheel rims - In sheet metal, 2.10 - 10"
Tyres - Tube type 3.50" - 10"
Length - 1,810 mm
Width - 740 mm
Running weight - 116 kg
Fuel tank capacity - 8 litres (of which 1.6 litres reserve)
Emissions - Euro 1
