Fri, 07 Nov 2008 21:29:09 +0000
Fri, 07 Nov 2008 21:29:09 +0000 quote
Are there any tricks to removing the front wheel pivot bearings/races? I've removed and disassembled the front fork of my '61 VBB, and all that's left is to remove is the pivot roller bearings so that I can strip and paint the fork before reassembling. But I can't get the darn things out. I've tried tapping them out from inside with a long pin punch, but they don't budge (althought that caused all the roler bearings to fall out, but the race doesn't move). I tried heating the outside with a blowtorch, but no luck either. Any other tips? I might have to just mask the openings and hope that no rust/paint chips get in there, but that seems pretty risky.
Thanks...
-Dan
Fri, 07 Nov 2008 23:12:16 +0000
'83 PX125E (little Red) / '09 Fuoco (unnamed)
Fri, 07 Nov 2008 23:12:16 +0000 quote
Sorry... thought you were referring to the lower bearing race on the tube... not the pivot
Best I could find was the Stella Service Manual - page 100. Shows using a press to separate the bearings.
Sat, 08 Nov 2008 01:10:46 +0000
Pha que
Pha que
Sat, 08 Nov 2008 01:10:46 +0000 quote
pic please....
You most likely will need to use a small hydraulic press.
That was my experience with a very old Sprint front end.
Sat, 08 Nov 2008 01:38:53 +0000
Sat, 08 Nov 2008 01:38:53 +0000 quote
Thanks for the suggestions. I'll post a pic tonight or tomorrow.
-Dan
Sat, 08 Nov 2008 19:46:29 +0000
Sat, 08 Nov 2008 19:46:29 +0000 quote
Here are the pics of my front fork. The pivot bearing I'm trying to remove is the one in the upper right corner of the first picture. Well, I guess that's kinda obvious since it's the ONLY bearing on the fork right now! It seems to be in two parts, i.e. one race on each side, with rollerbearings not ballbearings. In two pieces because there was a zerk grease fitting in the middle (which I've removed for sanding).
So since there are two of them, can I still use a hydralic press to push them out? Is there anything in the middle that they will snag on, I wonder?
Thanks for any hints!
-Dan
Close-up, you can see the rollers are loose in there (a few came out already)
The front fork, kinda upsidedown in this picture of course...
Sat, 08 Nov 2008 20:17:14 +0000
'76 Rally
'76 Rally
Sat, 08 Nov 2008 20:17:14 +0000 quote
crazy I'm in the exact same place as you with my rally fork. I was just about to go the torch route. This will suck if we gotta press them out.
I'll give a go with the torch and let you know if I get anywhere.
Sat, 08 Nov 2008 21:27:39 +0000
Sat, 08 Nov 2008 21:27:39 +0000 quote
can you press both races straight through?
Tue, 18 Nov 2008 06:24:39 +0000
Tue, 18 Nov 2008 06:24:39 +0000 quote
Any luck getting them out? I'm still stumped, but haven't really had much time to work on it.
-Dan
Tue, 18 Nov 2008 12:11:43 +0000
Tue, 18 Nov 2008 12:11:43 +0000 quote
you should really use a press to remove the races and install the new bearings.
however, you can get away by clamping the fork tightly in a vice and using a jackscrew arrangement with appropriately sized washers to extract the pieces, just expect to use alot of foul language.
freeze the bearing and heat the fork lightly and install should be a bit easier...
best,
-greasy
Tue, 18 Nov 2008 13:33:39 +0000
Tue, 18 Nov 2008 13:33:39 +0000 quote
I, too, would suggest propane torch + appropriate sized socket used as a drift to remove the inner race, twisted together with a big bench vice. It will press the inside race out.
Tue, 18 Nov 2008 18:41:46 +0000
'76 Rally
'76 Rally
Tue, 18 Nov 2008 18:41:46 +0000 quote
dch,
Nope, I spent better half of a weekend with the torch, drifts, and vise and no love. and yes greasy, a lot of foul language.
I caved and took it to scooterworks. Not the route I wanted to go, but I have to realize when I need to call in the big guns, they have the tools and knowledge I just can't match.
Sorry I don't have any tips to pass along. Good luck with your's though, I hope you succeed where I failed.
Tue, 18 Nov 2008 18:48:12 +0000
Tue, 18 Nov 2008 18:48:12 +0000 quote
Thanks everyone for the info. So when you took yours to scooterworks, did they use a press to remove it, do you know? I think there might be a hydraulic press here at work that they might let me use (although I'll have to forgo the foul language if I do it at work!).
-Dan
Tue, 18 Nov 2008 19:12:15 +0000
Tue, 18 Nov 2008 19:12:15 +0000 quote
For future reference, you can get a 10,000 pound hydraulic press at harbor freight for $200 or so.
It would have made short work of that.
Tue, 18 Nov 2008 20:16:12 +0000
Tue, 18 Nov 2008 20:16:12 +0000 quote
Never thought to look there. Here's a 6-ton one for $75.00 -- would that work?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1666
The problem with tools like this is knowing when to use them, versus when using them will do damage. Which is why this group is so great - you guys have that expertise! Thanks again.
-Dan
Tue, 18 Nov 2008 22:56:07 +0000
'76 Rally
'76 Rally
Tue, 18 Nov 2008 22:56:07 +0000 quote
the deacon wrote:
Not the route I wanted to go, but I have to realize when I need to call in the big vegetable peelers,
haha, eric was that you? good call.
I'll be getting the fork back on the 5th or so. Not sure if they are going the press route, I can find out when I pick up.
I agree, sometimes more damage can be done, its not just the right tool but the knowledge of how and when to use it. (which is where this site come in)
  DoubleGood Design
[ Time: 0.0294s ][ Queries: 4 (0.0080s) ][ Debug on ][ 298 ][ Thing Two ]
