Hi,
Any experience this? I just purchased a Cupini rear view mirror for my P200.
I think I installed it correctly, but I cant seem to get it to change the up/down
angle and it reflects the road with no horizon. I am not that tall either.
![]() 1978 Vespa P200e
Posts: 231 Location: SoCal |
Sat, 08 Nov 2008 03:08:57 +0000
Hi,
Any experience this? I just purchased a Cupini rear view mirror for my P200. I think I installed it correctly, but I cant seem to get it to change the up/down angle and it reflects the road with no horizon. I am not that tall either. |
![]() '78 Super 150 Mk II ported DR177, banded clutch, ASC Big Bore
Posts: 664 Location: Ottawa, ON, Canada |
Sat, 08 Nov 2008 15:31:57 +0000
Re: Cupini Mirror mounting. Changing angle?
checkflag wrote: Hi, Any experience this? I just purchased a Cupini rear view mirror for my P200. I think I installed it correctly, but I cant seem to get it to change the up/down angle and it reflects the road with no horizon. I am not that tall either. Here's a pic of my mirrors: ![]() Oddly, the legshield ones can be swivelled on their mounts, yet the 14" handlebar ones cannot (despite the mirror itself being the same shape and style). |
![]() 64 Vespa 150cc
Posts: 84 Location: N.Westchester County,NY |
Sat, 08 Nov 2008 19:58:29 +0000
I never got them to work properly and finally gave up on them and bought the under headlamp mounted ones scooterworks sells.
![]() Sun, 09 Nov 2008 00:12:46 +0000
Sponsor
Posts: 4200 Location: San Diego, Ca |
Those brackets they mount to need to be bent down a hair downwards with a pair of pliers or such. Then they work great.
Tue, 11 Nov 2008 03:55:54 +0000
the one I got was defective. the neck was bent poorly and didnt allow the
mirror to aim in the correct direction. I got another one, but to be honest, it just vibrates way to much. I am going to return it. |
Sponsor
![]() DL200, TV2, Vega, Lui, GTS
Posts: 750 Location: Orange, NJ |
Wed, 12 Nov 2008 00:33:52 +0000
checkflag wrote: the one I got was defective. the neck was bent poorly and didnt allow the mirror to aim in the correct direction. I got another one, but to be honest, it just vibrates way to much. I am going to return it. On another post you mentioned you were having problem with gas mileage and fouled plugs. Check the bearings on both sides of your crank. If they are bad, or seated incorrectly, the crank could be moving slightly and causing probs with your seals. That would cause plug fouling problems and could also cause excessive vibration. |
Wed, 12 Nov 2008 01:17:36 +0000
Andrea wrote: checkflag wrote: the one I got was defective. the neck was bent poorly and didnt allow the mirror to aim in the correct direction. I got another one, but to be honest, it just vibrates way to much. I am going to return it. On another post you mentioned you were having problem with gas mileage and fouled plugs. Check the bearings on both sides of your crank. If they are bad, or seated incorrectly, the crank could be moving slightly and causing probs with your seals. That would cause plug fouling problems and could also cause excessive vibration. As for the bearings and seals, I just rebuilt the engine last week. I had the guys at baritalia look it over and everything seems to be in order. the plug is showing more of a carbon fouling now, rather than the wet fouling I was getting last week.. I am hopeful that a little carb tweeking will get things in order. |
