gts250ie
gts250ie
can anyone tell me what plugs are compatible with my scooter?the manual says that i should use a Champion RG 4 PHP,altho i came across a site that said i could use an NGKIRIDIUM.can anyone confirm?
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
"Should" trumps "Could" in my opinion. If the manufacturer says Champion, then I would use the Champion.
@guzzivox avatar
2009 GTS 250 Super '02 Moto Guzzi Lemans Tenni
@guzzivox avatar
I installed the NGK Iridium and have no problems at all. Runs great!
@2011super avatar
2021 GTS 300 Touring
@2011super avatar
I set up a group buy here a few months back and I am using a Denso Iridium. If you look for that old group buy post you will see actual model number info too.
@snapshot05 avatar
WHOoligan
WHOoligan
@snapshot05 avatar
For years I ran Champs in my 2 strokes, but they kept fouling, so I tried NGKs and they stopped fouling.
I have a champ in my GTS, but I plan on going NGK next.
As for going with what the manufacture says, I wont ever use Savas again.
Find one you trust and works for you is what Id suggest.
Manny
@dougl avatar
El Macho
0/0
El Macho
@dougl avatar
0/0
Odd opinion!
The owners handbook lists an NGK alternative. They are more expensive than Champions. Probably more of a manufacturer cost-cutting exercise!
NGKs tend to run slightly better than champions IMHO.
@cincinnati_john avatar
'07 GTS-250ie - sold and gone
The stock Champion in my GTS fouled after 4000 miles. Replaced it with the NGK CR8EIX. Same heat range as the Champion. 500 miles and running fine.
@2011super avatar
@2011super avatar
Link to group buy with model numbers.
@cateyez13 avatar
'84 PX125E ^..^
@cateyez13 avatar
'84 PX125E ^..^
Re: sparkplug for gts250ie
I Was wondering this myself. My manual doesn't state an alternative spark plug. What would the NGK equivalent to the Champion RG4PHP? I was looking online for prices of the RG4PHP and they are pricey too.
Thanks,
Cat
@2011super avatar
@2011super avatar
Thanks,
Cat
I supplied a link above that I would highly recommend reading.
@cateyez13 avatar
'84 PX125E ^..^
@cateyez13 avatar
'84 PX125E ^..^
Thanks,
Cat
Whoopsies ... Thanks!
@bob_cowley avatar
GTS250, P200E
@bob_cowley avatar
GTS250, P200E
I found that the original Champion plug in my Quasar engine was gapped at about .015 in, but the manual says to use about .025 in. I regapped mine to .025 in, but can't say whether it provides better performance.
Cheers,
Bob
@2011super avatar
@2011super avatar
I will personally never use anything but a NGK or Denso Iridium plug. They are a little more but still well under $10 a piece.
@scooter_d avatar
GTSie 250 - Black Its the New Red
@scooter_d avatar
after about 8k I switched to the NGK and have had no problems. to find a cross reference access the NGK UK site and type in your scoot model.
[ Time: 0.0132s ][ Queries: 3 (0.0039s) ][ live ][ 334 ][ ThingOne ]
