Noticed today that the right side of the boot lid on my 400 is slightly higher than the left. loosening the four screws that hold the lid to the hinges only allowed me to shift the lid forward or backward, not up and down. is there a way to adjust the hinge itself?
When my 400 got smacked I was looking at replacing it since I really liked the storage. Every one of the 400's in stock had finish issues - the one I selected had a skewed trunk as you describe. The dealer said there was no way to adjust since it's basically attached to the frame. My guess is bad jigging when welding teh frame. That's when I decided to move up to the 500.
Now practically speaking I'm guessing you could look at slotting the hole where the screw goes through to make your own "adjustment". A Dremel took should be up to the task. |
BubbaJon wrote: When my 400 got smacked I was looking at replacing it since I really liked the storage. Every one of the 400's in stock had finish issues - the one I selected had a skewed trunk as you describe. The dealer said there was no way to adjust since it's basically attached to the frame. My guess is bad jigging when welding teh frame. That's when I decided to move up to the 500. Now practically speaking I'm guessing you could look at slotting the hole where the screw goes through to make your own "adjustment". A Dremel took should be up to the task. ![]() |
![]() UTC
Posts: 22908 Location: Harriman, Tennessee, Tn |
chillicrab wrote: BubbaJon wrote: When my 400 got smacked I was looking at replacing it since I really liked the storage. Every one of the 400's in stock had finish issues - the one I selected had a skewed trunk as you describe. The dealer said there was no way to adjust since it's basically attached to the frame. My guess is bad jigging when welding teh frame. That's when I decided to move up to the 500. Now practically speaking I'm guessing you could look at slotting the hole where the screw goes through to make your own "adjustment". A Dremel took should be up to the task. |
old as dirt wrote: this is part of the piaggio 1 off program. Your scooter is now a very unique 1 off machine and nobody else has 1 like yours. ![]() |
![]() UTC
chillicrab wrote: old as dirt wrote: this is part of the piaggio 1 off program. Your scooter is now a very unique 1 off machine and nobody else has 1 like yours. ![]() |
old as dirt wrote: chillicrab wrote: old as dirt wrote: this is part of the piaggio 1 off program. Your scooter is now a very unique 1 off machine and nobody else has 1 like yours. ![]() |
Puch SRA150, MP3 400, Moto Guzzi 750 Nevada, BMW K75S
Posts: 264 Location: Glendale AZ (was Albury NSW) |
chillicrab wrote: any idea how they did it? 2) Loosen the bolt which clamps the handlbar mount to the steering stem. 3) Twist/move the handlebars sideways until they are correctly aligned = point straight ahead when the wheels are tracking straight ahead 4) Tighten clamp bolt and replace handlebar mount cover. That's the summary - you might find real instructions in the service manual, but you might not either, since for the average motorcycle technician that is a no-brainer. Cheers, and all the best Trevor G |
![]() UTC
be very carefull when tightening that bolt for the handle bar. if it is over torqued you could crush the streering stem as it is hollow.
Trevor_G wrote: chillicrab wrote: any idea how they did it? 2) Loosen the bolt which clamps the handlbar mount to the steering stem. 3) Twist/move the handlebars sideways until they are correctly aligned = point straight ahead when the wheels are tracking straight ahead 4) Tighten clamp bolt and replace handlebar mount cover. That's the summary - you might find real instructions in the service manual, but you might not either, since for the average motorcycle technician that is a no-brainer. Cheers, and all the best Trevor G old as dirt wrote: be very carefull when tightening that bolt for the handle bar. if it is over torqued you could crush the streering stem as it is hollow. |
