Tue, 11 Nov 2008 21:59:40 +0000
200p piagio
Posts: 2 Location: 1513 n3 |
200p piagio
I took my vespa to motion sports on government way in CdA Idaho. They charged me 60.00 and returned the piagio in the same condition in which I took it to them I need an honest close to coeur d alene idaho fixit guy. My brake handle dosen't stop the bike and the kick start dosen't turn the motot over.shirleyfreeman@yahoo.com
![]() Tue, 11 Nov 2008 23:41:39 +0000
No Scooter no more...
Posts: 1611 Location: Brighton, England |
![]() No Scooter no more...
Re: 200p repair
shirleyfreeman wrote: I took my vespa to motion sports on government way in CdA Idaho. They charged me 60.00 and returned the piagio in the same condition in which I took it to them I need an honest close to coeur d alene idaho fixit guy. My brake handle dosen't stop the bike and the kick start dosen't turn the motot over.shirleyfreeman@yahoo.com there are many possible reasons for your predicaments so more info would be great. if your just looking for info on mechanics in your area, i'm affraid i'm not your man cheers |
Thu, 13 Nov 2008 06:08:42 +0000
200p piagio
200p piagio
The front brake handle is what's not grabbing. I see your in England. Nice spot if your used to Oregon Rain. Anyway, when I kick the lower unit it just slips right on past. I did replace the selector box because there were parts that ended up on the ground, so I knew it was broken. I thought the selector box cables were not tight enough. Since I took it to motion etc, I have been lead to believe that was not the issue. Now I have no idea. Any ideas from you.
Destroyer of Worlds
![]() LML Star 125, Vespa GT200
Posts: 2011 Location: London, United Kingdom |
Thu, 13 Nov 2008 08:11:11 +0000
Try adjusting the clutch cable. If it's too tight, the clutch will engage and the kickstart won't connect to the crank. If that doesn't work, you could have a broken kickstart gear or something more serious, which would require a rebuild.
To learn about your bike, check out scooterhelp.com or vespamaintenance.com. FYI, your scooter is called a Vespa P200E. |
Destroyer of Worlds
Thu, 13 Nov 2008 08:12:52 +0000
WRT your brake, make sure the cable is not broken.
Just so you know, the front brake on the P-series bike is not strong enough to lock the front wheel. |
