@gonzo avatar
GTS 250ie Yellow "Sunny"
@gonzo avatar
Hi everyone,
Has anyone of you taken of the front mud-guard? If so, do you have tips for me and maybe photos of the process?
cheers,
@paige avatar
LX150, MP3, Buddy
@paige avatar
LX150, MP3, Buddy
If you mean the fender, I think you have to drop the fork. Complicated.
@gonzo avatar
@gonzo avatar
Yes I meant the front fender, I think it's called front mud guard here in Europe...right? Any tips or photos well appreciated.
@jerryg avatar
2005 Dragon Red Vespa ET4 Speedster
@jerryg avatar
The way I did it was to crash into a large dog. Took it right off in many small pieces. Putting a new one on...drop the fork.
@ohsuchislife avatar
Vespa 300 GTS 14- / Vespa 180 GTR / Mini Cooper S Mk3 / 2002 200 disc / 1978 150 Super / 1963 Lambretta 150li
easy job mate ...
put a jack under frame to lift front wheel off of the floor
headset off .. headlight etc speedo ..
undo the from brake caliper and remove brake fluid ,,
front handelbars remove or undo head bolt and pull to one side ..
undo speedo for front hub .. and and brake line from caliper ..
pull off black plastic spacer on fork under lock nut with a flat center punch and them spacer .. then undo head nut .. and while holding front hub slide the fork and remove front hub .. mud guard as a complete unit ... you can take off the mud guard by removing the three screws holding it on ..
EASY EH ..
@bluebuddha avatar
Kitted ET4.
@bluebuddha avatar
Kitted ET4.
Not recommended if you've never done it before. Tricky stuff involved with the steering column and if you mess that up...not good.
@greasy125 avatar
@greasy125 avatar
generally, this is a job better left to the specialist. there are a few speciality tools involved and some very intricate processes.
best,
-greasy
@gonzo avatar
@gonzo avatar
Thanks guys, I'm contemplating my actions...maybe I'll just dive in...maybe not..he he...
But thanks guys 8)
[ Time: 0.0089s ][ Queries: 3 (0.0029s) ][ live ][ 313 ][ ThingOne ]
