@jlb avatar
2007 Vespa GTS 250ie
@jlb avatar
I bought a Widder heated vest, so I also bought a plug kit from Scooter Works to hook it into . It came with no instructions,and I have seen several instruction lists, some which look easier than others.
I have a 250gts, and need the proper instructions if anyone has them.
Also, I would like to know if I could rig it to my wifes LT150 somehow, maybe directly to the battery.
Thanks in advance.
@midnight_rider avatar
09 GTS (sold) 2014 NC700XD
Hi,
Have a look in the Project Reports section, there are quite a few instructions there...
Good luck with installing it, it really is not that hard!
@mullman avatar
10 Dragon Red GTS300, 67 BMW hack
@mullman avatar
Behind the left panel should be an alarm harness.
Get your multimeter and pick whether you want constant +12 or switched +12 (key on), both are available on that harness.
I cannot remember which color off the top of my head.
There are a couple of decent chassis grounds to pick from.
Or you could just run it to the + terminal on the battery (with fuse of course!)
@cincinnati_john avatar
'07 GTS-250ie - sold and gone
See this thread for pinouts of the alarm connector:
Turn Signal Beeper and 12V Power Outlet on a GTS
@guzzivox avatar
2009 GTS 250 Super '02 Moto Guzzi Lemans Tenni
@guzzivox avatar
Going direct to your battery, with a fuse at the battery end is your best bet. Also allows you to use a battery tender. It wasn't that difficult to fish a wire(with a cable shield from Radio Shack) from the battery up to the left knee panel. Good luck!
A battery tender can be connected through a power outlet, provided the outlet is fed upstream of the key switch. Se above thread.
@scooter_west avatar
Sponsor
Sponsor
Did you buy it from us or from Scooter Works? I didn't know they sold one. If it was from us, we have a very simple new wiring harness that connects to the running light in the horn cover. Just disconnect that wire and plug the power plug into those two clips you just separated.
If it's from someone else, you will have to sort out your own wiring via one of the methods mentioned above.
@jlb avatar
@jlb avatar
Yes, I got it from you, but there were no instructions included. Can you help me out?
Sponsor
Sponsor
There are instructions on our website. There's a link on the power plug page of our website, which appears to be down at the moment. Take a look there when our site comes back up. Essentially, you will remove the left knee pad and horn cover. The power plug will replace the left knee pad, and the connectors will go into the electrical clips for the horn cover running light. More detailed instructions are on the site.
@jlb avatar
@jlb avatar
Thanks.
@jlb avatar
@jlb avatar
OK, I'm at step one: Disconnect the battery.
Where in the hell is the battery?
Sponsor
Sponsor
Between your feet if you're on the scooter.
@o0dano0o avatar
GTS 250
@o0dano0o avatar
GTS 250
Under the rubber thing on the floor between where your feet go. Take out the 4(?) screws, and thar she blows.
@jlb avatar
@jlb avatar
Under my feet?
No wonder the Italians lost in WW2.
Sponsor
Sponsor
JLB wrote:
Under my feet?
In the center channel between your feet.
@jlb avatar
@jlb avatar
Done.
That was cake.
Getting my front rack off was harder than the install.
Two thumbs up!
@teacherquinn avatar
Motorsport's powerplug won't work on an '07 GTS. The harness is too small. Found that out the hard way! Check the white plug on the contraption and compare it to what you find behind the black panel. '07 comes with one large plug. The earlier GTS have a couple different ones back there. Good luck!
@guzzivox avatar
@guzzivox avatar
same thing happened to me with the GTS250 super. I ended up just wiring direct to the battery.
Sponsor
Sponsor
We've actually changed the harness to work with all GTS models now:
JLB wrote:
Done.
That was cake.
Two thumbs up!
If you still have a power plug with an incompatible harness, let us know and we can send an updated harness.
Sponsor
Sponsor
These still don't work with the Super yet...
@jlb avatar
@jlb avatar
Whatever they sent me works perfectly.
I just went on a long ride, and it was like I was sitting in a hot tub.
It's only in the 50s here, but I actually had to turn the vest off at one point because I was too warm. The rest of me was in envy of the part covered by the vest.
@neducati avatar
2016 Vespa GTS 300 Settantesimo
@neducati avatar
GT200 Power Plug
Hi Max-
I just bought this item for my GT200 and it was delivered today.
There are two male spade connectors on the back of the socket. On the wiring harness there is a black and a white wire, each ending with female spade connectors. Since both spades are the same size, it is not obvious which wire clips onto which connector on the back of the socket. Does it matter which female connector (black vs. white) wire goes onto which male connector?
Thanks.
Ned
@jlb avatar
@jlb avatar
Re: GT200 Power Plug
Neducati wrote:
Hi Max-
Thanks.
Ned
I called them with that question too. The spades are arranged like a letter "T". The red wire goes to the center spade. The ground goes to the outer spade, or the top of the "T".
⚠️ Last edited by JLB on UTC; edited 1 time
@neducati avatar
@neducati avatar
JLB wrote:
I called them with that question too. The spades are arranged like a letter "T". The red wire goes to the center spade. The grouund goes to the outer spade, or the top of the "T".
Thanks for the quick reply.
I don't have a red wire, only white and black. Which is the ground?
Sponsor
Sponsor
Neducati wrote:
Hi Max-
Thanks.
Ned
The white wire is the power wire and connects to the center gold spade terminal. The black wire is the ground, and goes to the outer silver spade terminal. The female spade connector on the black wire sometimes needs to be pinched down with a pair of pliers because it's a little loose on the male spade terminal.
@neducati avatar
@neducati avatar
Neducati wrote:
Hi Max-
Thanks.
Ned
Thank you Max! Much appreciated.
JLB wrote:
Done.
That was cake.
Two thumbs up!
You guys rock!
2011 BMW R1200 GS Adventure, 2016 Vespa PX 150
Hey!
I am very interested in that plug thingy. Got myself Vespa GTS 300. And I live in UK, London. Do you deliver to UK and is it very expensive?
Can you connect satnav to that plug?
@paul_g avatar
GTS 250ie
@paul_g avatar
GTS 250ie
I know it's probably too late, but an electric vest will draw at least 3.5 amps, probably more. I'm not convinced plugging into the alarm socket (or even the running light) is the best idea.
These are convenient power points for charging a phone or running a GPS or radar detector, but a steady 4 amp draw really should be wired directly to the battery and have its own dedicated fuse as close to the battery's terminal as possible.
Just my 2 cents.
It was a pain to snake wires through on my bike, but I'm very happy I did it.
I use my BMW electric vest with utter confidence knowing the wiring is a) sufficient and b) completely independent of the scooter's vital electrical/electronic functions.
P.
It's entirely safe to draw up to 10 amps from the GTS alarm connector.
See: https://modernvespa.com/forum/wiki-gts250ie-alarm-connector-pin-assignments
See also: [topic22962]
@jlb avatar
@jlb avatar
I used my Widder vest on several rides this winter with zero problems.
@paul_g avatar
GTS 250ie
@paul_g avatar
GTS 250ie
Thanks John. This place is a great source of information for those who look stuff up.
P.
@crawley avatar
GTS 250 Super
@crawley avatar
GTS 250 Super
Are there any work arounds to getting it to work (short of plugging directly in to the battery) or plans to get it working with the Super's? I was eyeing adding the product for hooking up a GPS for a summer road trip.
If the Super has an alarm connector behind the left knee panel, similar to the GTS250, you could tap into that: Turn Signal Beeper and 12V Power Outlet on a GTS
Max,
Can you provide the link to the power plug page of your website?
@miguel avatar
@miguel avatar
Max. Do u sell a mating connector for the alarm connector behind the left kneepad?
Thx
Miguel
[ Time: 0.0249s ][ Queries: 8 (0.0072s) ][ live ][ 335 ][ ThingOne ]
