@sh_lim avatar
mp3 250
@sh_lim avatar
mp3 250
The trunk to my mp3 250 is giving me trouble. We need to push the key in and turn it counter clockwise to open, nothing happens today while I try to open the trunk. It is sort of like nothing is happening at the switch. Anyone else have this problem before? Crying or Very sad emoticon Cheers!
Do you have key-fob remote for it on the 250? If so does that work?
If not, I'd suspect the cable connection at the latch end. It may have come adrift...
piaggio mp3 500
piaggio mp3 500
mine did the same
mine did the same thing and still does once in awhile on my 500, my remedy is a good ol smack on the rear seat.. Works eveytime for now, it's just bad alighnment...
@chillicrab avatar
MP3 398.9
@chillicrab avatar
MP3 398.9
i had some trouble opening my fuel cover once. i had to jiggle it while turning the key to get it to open. maybe you can do the same with the trunk (get someone to help you unless you have arms like an orangutan) Razz emoticon
@sh_lim avatar
mp3 250
@sh_lim avatar
mp3 250
Laughing emoticon I have been doing that since day one cos the fuel cover will not tilt open unless i give it a push at where the hinge is. And you are right, I do not have arms like an orangutan. Razz emoticon And jimc, you might be right about the latch disengaging cos this morning I put in an overall and my Alpinestar riding suit into the trunk! I was thinking about this an hour ago. I will give it a check and update on this later. Cheers!
@sh_lim avatar
mp3 250
@sh_lim avatar
mp3 250
Re: mine did the same
Laughing emoticon Problem gone! Gave the latch a bit of shake and slam the cover down hard! Good as new. Razz emoticon Cheers!
@ramblerdan avatar
2009 MP3 400
@ramblerdan avatar
2009 MP3 400
Fuel door
I had the same problem. See this thread.
@emptynest avatar
MP 3
@emptynest avatar
MP 3
My fuel cover always gives me a hard time. I have to turn the key and pry it with my finger, then it pops open.
@sh_lim avatar
mp3 250
@sh_lim avatar
mp3 250
Try pushing down the other end where the hinge is.I do that all the time and the cover will pop open when there is pressure at the hinged end. Cheers!
@emptynest avatar
MP 3
@emptynest avatar
MP 3
Yes, I think that's what I do to pop it open..
MP3 500
MP3 500
sticking fuel door
I had the same problem within the first week of owning my 500. I discovered there was a slight amount of corrosion on the latch and once I cleaned everything up and put a drop of oil on it the door pops open as advertised.
@sh_lim avatar
mp3 250
@sh_lim avatar
mp3 250
Re: sticking fuel door
Laughing emoticon good work done! Might try it myself. Cheers!
[ Time: 0.0126s ][ Queries: 3 (0.0033s) ][ live ][ 313 ][ ThingOne ]
