01 ET4
01 ET4
I am hooking up:
- garage door opener (https://modernvespa.com/forum/topic37512)
- voltmeter
- a pair of spot lamps
- cigarette lighter (not a 12v accessory outlet - well, thats on the bike but not an accessory in question)
they are all going to be on relays and only on when the bike is on.
Is this what the wiring is supposed to look like?
http://www.djstonerokk.com/vespa/wiring.jpg
thanks for all your help!!!
01 ET4
01 ET4
or maybe my voltmeter doesnt need a relay.
this is the wiring diagram from the instructions:
www.djstonerokk.com/vespa/voltmeter.jpg
thanks again!!
@snapshot05 avatar
WHOoligan
WHOoligan
@snapshot05 avatar
thanks again!!
I have two accessory lights on my scoot, and the battery drains power like a drunk getting free booze. I rarely use them because the charging system is weak.
But I dont have mine running off a relay.
01 ET4
01 ET4
thanks again!!
I dont really want to run the lights constantly. its more to add to the aesthetics of the bike. but i want them to work AND id like for them to be wired properly.
anyone have any input on whether my wire plan is on point or not!?
thanks!!
@snapshot05 avatar
WHOoligan
WHOoligan
@snapshot05 avatar
I didnt realize your scoot was an ET, I dont know anything about the ET series. You might want to hit up moderator Jimc, I think he was an electrical engineer, he seems to know his stuff.
Good luck
Let me know how it turns out.
Manny
@starreem avatar
07 GTS250(RIP), 13 GTS300, Several Lambrettas
@starreem avatar
Why all the relays if you're adding new switches as well? Are the switches you're using not rated for the load you're trying to switch?
01 ET4
01 ET4
switches are not rated.
The voltmeter and the garage door opener do not need relays, they take sweet FA in terms of current. The others are better off with relays.
Otherwise the wiring looks good to me.
@timbit avatar
Fly 150, 2006 black
@timbit avatar
Fly 150, 2006 black
Why not use just one relay?
What you drew will work, but it seems like a lot of redundancy.
01 ET4
01 ET4
unsure.
but this seemed to make trouble shooting easy in the event that i need to.
thank you sire!
@bj_villiers avatar
GTV
@bj_villiers avatar
GTV
thanks again!!
Manny, its getting time to hook up my fog lights, I really don't undertand my instructions that came with the HD kit. Each lamp has one wire coming from it. They are supposed to be joined together and go to the switch as one wire. The supplied toggle switch comes with 2 prongs- one in the center, one on the side, If I go to the battery with the center like a cigarette socket don't the two coming from the lamps go to the other other prong. There is an inline fuse to the switch. But what is my ground wire ?
I asked the guy at the dealership and he said to know if the bike while running is charging the battery with the fog lights on put a volt meter on it.I'm not sure if it needs a relay, and being non electrically astue what the relay does. Will it amplifiy ? The way I will be set up is that the center light by the horn will be blocked by a bag. I don't think I should use this as a power source but I want to disconnect the bulb.
Based on you saying fog lights draw too much power I thought I'd ask.
[ Time: 0.0149s ][ Queries: 3 (0.0051s) ][ live ][ 313 ][ ThingOne ]
