@percival_marsh avatar
2004 ET2 "Josephine"
Hi there,
Just a quick question regarding starting your scoots in the morning. I use my machine for commuting at present and I need to be out of the house by 06:15 each morning to catch a ferry. The problem being that by the time I've woken up, shaved, showered and all that good stuff, I'm usually running late. This tends to mean opening the garage starting the engine and off I go.
My question is: is this bad for the engine and do I need to get up earlier to let the engine idle for a few minutes? (Which I'm sure my neighbours would love).
Many thanks in advance...............
@el_josh_aka_ruby avatar
GTS 250ie
GTS 250ie
I have to let mine idle till 2 bars on the temp guage. If I don't my oil light comes on when I slow down. (Yes I am finally taking it to the dealer to have it looked at, but I'm not happy about it) Other than that I think it's ok to just start and run. I can't do that on my GF's Ducati though. It has to warm up or it will stall out. I've done this twice mid turn in an intersection no less. Scary to say the least, Lession learned pants cleaned. 8)
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
If everything is running correctly, I don't see any reason to have to idle it for more than a few seconds. I say at least a few seconds just so you can hear the engine and check that everything sounds and feels normal.
@dutchman avatar
Gilera Fuoco 500 Verde Chianti
@dutchman avatar
As long as you do not WOT right away you'll be fine.
You say you have your scoot in the garage so it will not be that cold.
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
my morning routine with the scooters is start it up, give it a little rev or two, drive off. on really damp or chilly days they take a minute or two of riding to clear their throats, but that's as much warming up as they seem to need.
@paul_g avatar
GTS 250ie
@paul_g avatar
GTS 250ie
Start the bike, then put on your helmet and gloves. That's long enough--just be gentle with the throttle over the first minute or two.
No harm will be done, and you won't have to take risks to "make up time" or listen to guff about being tardy.
P.
@got_mine avatar
@got_mine avatar
Re: Early morning starts...........
Percival Marsh wrote:
Hi there,
Wake up earlier ?
I agree with others, as long as you do not try to do a wheelie coming out of the garage everything should be alright.
Keep an eye on oil level though, easy to forget when rushing around...
Thanks for the advice people, invaluable as ever........
GTS 250ie
GTS 250ie
@benito avatar
@benito avatar
The only time I really let the engine warm even a bit is when the temperature is below freezing. Otherwise I really just start her up and get going.
@dutch avatar
LXV 150 GTV 250
@dutch avatar
LXV 150 GTV 250
I just fire it up and go. Take it easy for the first couple of blocks as when it's really cold it'll stumble a bit.
I tried leaving it running the other day at the coffee shop. Tried to put it up on the centerstand while it was running. I grabbed the throttle to pull it back. Big mistake. I did get it stopped after it ran over my foot !
Glad there wasn't anyone around to see that ! DOH !!
@aviator47 avatar
@aviator47 avatar
Actually, that's a very thoughtful question-
"Does my scooter deserve foreplay"
Not a commonly expressed concern.
Al - the dirty old man
@ulysse avatar
Vespa LX 125
@ulysse avatar
Vespa LX 125
Are you using the recommended 5W-40 engine oil?
When did you do your last oil change?
Cold weather and and oil viscosity could explain this behaviour...
GTS 250ie
GTS 250ie
Problem fixed! Clown emoticon
https://modernvespa.com/forum/topic38151
@ulysse avatar
Vespa LX 125
@ulysse avatar
Vespa LX 125
Hehe cool...and my thought was right (I am using 0W-40 too)
Why did you open a new topic?
GTS 250ie
GTS 250ie
Because I am El Josh and I can do that!
[ Time: 0.0132s ][ Queries: 3 (0.0038s) ][ live ][ 313 ][ ThingOne ]
