2006 GT
2006 GT
Why does it need a foam filter instead of just plugging it off? and if it absolutely needs a foam filter what are you guys using?
thanks!
0:7 And counting
0:7 And counting
It doesn't absolutely need a foam filter, it's just a precaution.
The consensus from sometime back, when we first learned the ins and outs of the evap hose, was that blocking it off would make the engine run poorly, as it was (seemed to be) tuned to allow for some air to come in through that port. Try blocking it off, though. If it runs fine, don't worry about it.
@oopsclunkthud avatar
3:5
I think the evap port on the carb is the vent for the float bowl. If so it needs to be at atmospheric pressure for the carb to work right.
@boxerdad avatar
BV 500
@boxerdad avatar
BV 500
It must depend on the application. On my injected BV it is a vacuum port that just gets capped off.
0:7 And counting
0:7 And counting
Ah. That would make some sense, then.
0:7 And counting
0:7 And counting
Yeah, the injected engines are a totally different set of rules.
@chukstr avatar
Dragon Rosso LX 150
@chukstr avatar
Dragon Rosso LX 150
To answer one question, check this out Evaporator Hose Removal -- Cheap and Easy Filter
PX200E X 2
PX200E X 2
evap is blocked off on my LT. they stuck the probe up the pipe and 'tuned' it after the evap was removed and it runs great, 13K right now
@salty_dodd avatar
(GT200L) ... no more scoot :o(
@salty_dodd avatar
The GTS is injected isn't it?
Is it affected by the EVAP hose?
bv 250
bv 250
I just stuck a cheap two dollar inline fuel filter in the hose. I have had problems with condensation clogging up the filter and hurting performance on foggy mornings and I would have to blow it out. Do we really not need one ? Cause that would be great.
0:7 And counting
0:7 And counting
It is.
Yes, although in a slightly different way. The most common failure case for the GTS evap system is the formation of vacuum in the gas tank, which typically causes the bike to stumble at high speeds (say 70mph) but still well below the rev limiter. This is a simple gas starvation issue, as the vacuum inhibits the gas pump from getting the proper pressure to the injector.
Unfortunately, it's a lot harder to disconnect the evap system on the GTS, and you'll usually end up cutting the hose or mangling the one-time-use clamp keeping the hose connected. You've also got to block off the port coming from the intake manifold that used to go to the evap system.
[ Time: 0.0146s ][ Queries: 4 (0.0056s) ][ live ][ 313 ][ ThingOne ]
