Sat, 22 Nov 2008 16:22:48 +0000
VNB4T 1963 Vespa
VNB4T 1963 Vespa
Sat, 22 Nov 2008 16:22:48 +0000 quote
hi there, I have a 1963 vnb vespa (see following post):
http://www.modernvespa.com/forum/topic34193?view=previous
and havnt done much with it, however I have a problem that I would like some advice on. it was starting well with a couple of kicks a couple of months ago, until it started to play up - I like to kick it over now and again just to blow the cobwebs out.
it was firing, running for about 3 seconds, then cutting out, and from there it wouldnt start again.
now - it doesnt start at all, regardless what I try.
I have had the plug out and cleaned it up, checked for a spark against the engine and all looks good.
I have taken the air filter off, and put a cap of fuel straight into the carb (just in case the fuel tap was a bit wonky), still nothing.
im not sure what to try next really, I would be happy if I got a single fire out of it at the moment, but it seems dead.
I intend to do a full resto on it, including an engine rebuild, but like I say, it would be nice just to get a fire out of it in the meantime to keep me happy
can anyone help me get this puppy running again
Sat, 22 Nov 2008 16:28:05 +0000
Sat, 22 Nov 2008 16:28:05 +0000 quote
Moved to the Not So Modern Forums.
Sat, 22 Nov 2008 21:42:54 +0000
Sat, 22 Nov 2008 21:42:54 +0000 quote
Was this fresh fuel? The bloody stuff goes off very quickly these days.
Sun, 23 Nov 2008 01:13:14 +0000
VNB4T 1963 Vespa
VNB4T 1963 Vespa
Sun, 23 Nov 2008 01:13:14 +0000 quote
well - its been in there for a couple of months I suppose - but I topped the tank up with some fresh stuff, plus I put some fresh fuel direct into the carb, either way - I would have thought U would have gotten a fire - at the very least?!!??
no?
Sun, 23 Nov 2008 13:30:01 +0000
Sun, 23 Nov 2008 13:30:01 +0000 quote
Have you checked the compression? Also, try a little bit of ether enriched fuel that has a bit more "ignitability"
Al
Sun, 23 Nov 2008 14:23:59 +0000
VNB4T 1963 Vespa
VNB4T 1963 Vespa
Sun, 23 Nov 2008 14:23:59 +0000 quote
I guess you mean by testing the compression you mean sticking your finger in the plug hole ??
Sun, 23 Nov 2008 14:30:21 +0000
Sun, 23 Nov 2008 14:30:21 +0000 quote
That's one approach. And then there's this:
Which is a wee bit more accurate.
Al
Sun, 23 Nov 2008 14:38:41 +0000
VNB4T 1963 Vespa
VNB4T 1963 Vespa
Sun, 23 Nov 2008 14:38:41 +0000 quote
haha - yes - I guess so, but for the lack of having one - I guess the finger test will do. there certainly feels like enough compression when kicking it over, and obviously when the plug is removed, its a lot easier
so I guess I have "some" compression
hmmmmmm not sure what to try
Sun, 23 Nov 2008 14:43:52 +0000
Sun, 23 Nov 2008 14:43:52 +0000 quote
A capful or two of ether directly into the carb would let you know if there is any ignition. Spray can engine starter fluid, for example. Just a try or two, lest you create lube problems.
Al
  DoubleGood Design
[ Time: 0.0275s ][ Queries: 3 (0.0044s) ][ Debug on ][ 298 ][ Thing Two ]
