Thought you might be interested to learn what was found at my unnecessary 5000KM (3000M) service.
Rear brake pads had about 1mm of material left on them
Front and rear brakes had air in the system. #
Both rear shock absorbers were shagged. #
Complained about my intermittent seat switch fault, and they are replacing it. #
My indicator switch was also replaced (I knew this was broken). #
# all items marked with the hash were/will be replaced under warranty.
For my money, I think you'd be nuts to
not take your scoot into a reputable dealer while it is still under the manufacturers warranty. Let them check it over and look for things like this. You might have to pay for the service, but I believe the value of the parts they replaced under warranty would probably have paid me back most of the cost.
I could not have determined the air in the brakes issue and probably would have just replaced the pads (at the most).
I'm sorry, but I strongly disagree with a carte blanch recommendation to not consider the 5000km service. I'm glad I spent $280 (service plus rear brake pads and consumables) so a qualified person could examine my machine and look for things that I never would have found.
Sure, I didn't learn anything about my machine, but I'm confident that all faults that presented themselves at the service (I am calling it that, because that is exactly what I received) are totally rectified.
That's my two cents. I'm sure I'm going to be shot down for speaking my mind on this subject, because there seems to be two clear schools of thought about paying for the "non-logbook" services. We must not lose sight that some members are not mechaically minded, and recommending that they don't consider a 5000KM (3000M) service could potentially be bad for them in the long run.
All I ask is that as individuals, you make up your own mind whether you get a shop to do your work, or you do some of it yourself.
