Piaggio Fly 50
Piaggio Fly 50
This post -- my first! -- has been a long time coming. Finally, after weeks of research, subsequent weeks of waiting for parts, then some frustrating days of troubleshooting, I got this mod done. Many thanks to all MV users -- and a special shout out to micbergsma -- for advice and expertise!
I have an Excalibur Grey Piaggio Fly 50, which I love (purchased August 2008 in Boston; have been riding all winter when not snowing or raining). As soon as I learned that the Fly's blinkers in Europe weren't those ugly DOT-approved pods, I wanted to do this mod, which I'd seen elsewhere in various forms on MV. Some people had simply replaced the stock incandescent running lights with LEDs, more ambitious folks had turned them into only blinkers, and one, with lots of cutting and ingenuity (which I didn't want to do and don't have), had actually added a 2nd bulb to the front running light lens housing and ended up with running lights and blinkers in front (these mods were not all on the Fly, but on the LX and other bikes). In a stroke of genius(?) and with the help of micbergsma, I figured that since the brake light on the Fly used a 3-wire socket and an 1157-type dual filament bulb (for a running light plus a brake light), I could use the same type of bulb in the front -- to make one bulb on each side for running lights and blinkers. I wanted to throw LED bulbs in all around too (since I'd already painted and upgraded the instrument panel to LEDs, which I'll try to make a post about another time), mainly for the look, but also for additional brightness and "instant-on" of LEDs.
I got all the bulbs from v-leds.com. The brake light was a simple swap, as was the rear license plate light. The blinkers, I thought, would be an easy fix too. Far from it. I realized that the low draw of LEDs caused them to blink fast. Then the rear amber LED blinkers wouldn't light. At all. In any configuration, with any LED bulb. I even returned bulbs and bought different more expensive ones, thinking the bulbs were the issue -- they weren't. The very last thing I figured out is that apparently, the wiring on the rear blinker sockets of the 2008 Fly is reversed -- positive to negative, negative to positive -- which apparently doesn't matter with the stock incandescent bulbs, but very much does with LEDs, which is why they wouldn't light. So, along with Signal Dynamics Corp's Dual Load Equalizer, all was finally fixed, and the blinkers were good to go.
As a part of this project, I did some accompanying basic paint and body work. The 2009 Flys have clear rear light lenses, which I really like, so I ordered clear blinkers lenses from a dealer, keeping the stock red one, which I liked. Now the rear blinkers look clear until they go on amber. I also replaced the front access panel with a black one, purely for looks (I should have painted it instead of buying it for $46!). I painted the rear hand rail and the side deflector strips black, and might paint the front mud guard and headlamp housing black eventually. I then removed the stick-on "Fly 4Tempi" from both sides, and the kick-start warning sticker, for a much cleaner all- around look.
Parts list:
2 3-wire 1157 sockets (original Piaggio parts), $13.80 each
2 left and right clear blinker housings, about $25 each
1 Red 1157 LED (rear brake), $20
2 Amber 1157 LED (front running + blinker), $20 each
2 Amber 1156 LED (rear blinker), $20 each
2 White 194 LED (license plate light and sidelight)
9 Posi-Lock connectors for 18-24 gauge wire, $8
1 Signal Dynamics Corp. Dual Load Equalizer, $20
misc. 18 gauge wire
black spray paint
metric allen keys to remove DOT blinker pods
Photos and explanations are below.
This is before I did any of the major work.  All I had done at this point was replace the front access panel with a black one and spray paint the screw glossy black.
On the left is the same socket that's stock in the brake light -- 3 wires, for running, brake and ground (to be used for running, blinker, ground in front). On the right is the stock running light socket, with only 2 wires.
I had to slice one of the tabs on the black 3-wire sockets to make it fit perfectly and lock into the front running light lenses.  Generic 3-wire sockets would be cheaper but wouldn't fit as perfectly with so little modification.
Now it was time to get to work.  These are all the pieces I removed (the side deflectors I only removed because I wanted them black; they do not have to be removed to remove the glove box).
I had wanted to use the the stock wire connectors and re-wire them to accommodate the 3-wires, but, it was impossible to do so without bending the metal connectors, so I cut the stock connectors off, and used Posi-Lock connectors.
RED wire: spliced into stock left blinker wire and run to white wire on new socket; GREEN: spliced into stock right blinker wire and run to white wire on new socket.  Stock running light wiring: yellow to yellow, black to black on new socket.
Here's a front view, before the blinker wires had been connected.  The LEDs are on running light mode with the Fly running for this shot.
Re-wired rear sockets to get LEDs to light, dual load equalizer makes them blink normally. Secured with double-sided tape, fits perfectly into the metal casing behind ignition. Purple to left positive, brown to right positive, black to ground.
Blue splice for dual load equalizer; red for "sidelight." Using wires from one of the stock POD blinkers, I spliced it into the left-hand running light wires (it actually blinks slightly when the blinkers are on).
Here's an underexposed photo to show the stock headlight bulb and the sidelight LED, spliced into  the stock running light wiring (pos+ground).
Painted black side deflectors glossy black.
Painted rear handrail glossy black.
Here's what the stock rear lights looked like.
Here's after the mods are complete.  I like the clear blinker look much better.
Here's after the mods are complete with blinker on.  Sorry, not the best photo.
I used dental floss to get the blue "Fly 4Tempi" stickers off.
It took about 1/2 hour using my too-short fingernails to scrape off the damn warning label!
This is an after shot, with right blinker on and left running light on.
Here's a cool night shot.
Here's an animation of what my Fly looks like running with the right blinker on.  It's an animation so it doesn't blink at that exact speed; this looks a little fast.
⚠️ Last edited by ajkostrow on UTC; edited 3 times
@micbergsma avatar
2003 ET4, 2005 LX 150, 1964 GS 160
@micbergsma avatar
Sweet!!!
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
Is there any reason they don't already come like that over there???
@phil001 avatar
vespa s 50cc
@phil001 avatar
vespa s 50cc
good job but there is text missing on the wiring description can you put a diagram on thanks
@killo avatar
I have a few scooters....
@killo avatar
US DOT requires that blinkers be a certain width apart. To meet the US spec, they add those little blinker "pods" under the headset. This conversion is the way they are built for most other countries of the world.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
I see thanks . Should have bought it over here then it would have come like that
@killo avatar
@killo avatar
Laughing emoticon You know how it is....once the government get involved, it cost twice as much, doesn't function as well, etc.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
well they're slowly killing off 2stroke in big cities in some countries just wating for them to say I can't ride mine anymore. I don't wanna have to go 4 stroke they are roughly 75%/cc (ci) weaker and dont sound half as nice to me. You can usually tell that a scooter is coming before you see it when you hear 2t. Dont notice a 4t scoot till it's in view.
Rant over
@phil001 avatar
vespa s 50cc
@phil001 avatar
vespa s 50cc
Rant over
My S 4t 4 vlave is like a 2t less the soound...
Piaggio Fly 50
Piaggio Fly 50
I fixed the missing text, and below made a wiring diagram (sorry for my less-than-adequate drawing skills).
RED circles: Posi-Lock connectors
BLUE circles: splice connectors for dual load equalizer
BLUE squares: splice connectors for wires to sidelight
BLACK circles: new 3-wire sockets
ORANGE circles: 1157 amber dual intensity LED bulbs
WHITE circle: sidelight
BLACK rectangle: dual load equalizer
Thick BLACK line: stock wiring harness
Thin BLACK line: wire spliced from stock running light positive and negative wire to sidelight
BLUE line: stock right blinker positive wire
PINK line: stock left blinker positive wire
RED line: new wire run from stock left blinker positive wire to white (gray) wire on new 3-wire socket
GREEN line: new wire run from stock right blinker positive wire to white (gray) wire on new 3-wire socket
--The negative stock blinker wires I snipped and left alone.--
YELLOW line: stock running light positive wire connected to yellow wire on new 3-wire socket (each side)
BLACK line: stock running light negative wire connected to black wire on new 3-wire socket (each side), also ground wire from dual load equalizer spliced into the stock running light negative (ground) wire
BROWN line: dual load equalizer right side blinker wire
PURPLE line: dual load equalizer left side blinker wire
Wiring diagram for project
Excellent first and second post. Thanks for posting this!
Piaggio Fly 50
Piaggio Fly 50
Thanks, jess. I can't wait to do some additional mods, and I'll be posting about the instrument panel mods I did at some point as well.
@danifly avatar
09 Triumph Bonnie, 06 Kymco P250, (Retired: 05 Stella , 08 Piaggio Fly150, 02 Yamaha Vino50, 07 Yamaha C3)
@danifly avatar
Awesome post.
thanks
2019 GTS 300 Super
2019 GTS 300 Super
Truly brilliant! Thanks so much for posting this. I never had the time to dedicate to do this on my own. I'll wave if I see you!
@chilln avatar
'09 Dragon Red, GTS 250
@chilln avatar
What is the purpose of that little sidelight inside the headlight assembly?
Piaggio Fly 50
Piaggio Fly 50
DaniFly wrote:
Awesome post.
thanks
Thanks for the comments. Please do wave, or stop to chat, as DaniFly did just a few days ago! What color is your Fly?
My understanding, from others on MV more knowledgeable than I, is that the sidelight (which isn't on Fly 150s) is for bikes made for countries that don't have daytime running light laws. These days, they may be a relic that haven't yet been purged from the manufacturing process (even in, say, Europe, where such laws, for all I know, now do exist).
My bike came with the bulb and wiring harness installed, but just not connected to anything, so for no particular reason, I just wanted to make it work so I spliced it into the left-side running light wiring.
The little LED I used in the sidelight pictured above, and a second identical LED which I also used for the rear license plate light, mysteriously burned out in unison several weeks ago, so I've replaced them with the original 5W incandescent bulbs (which don't have that blue-ish white LED hue, but might actually be brighter).
The blinkers, front and rear, are still working great, and look awesome.
@vollgashero avatar
2009 Piaggio Fly 50 2009 Piaggio Fly 150
@vollgashero avatar
Re: The Ultimate Euro signal conversion - Piaggio Fly 50
Parts list:
misc. 18 gauge wire
black spray paint
That looks AWESOME!! I have the 2009 so the tail lights are like that stock but i like the front turn signals! That is awesome! Oh i also love the Silver and black colors! makes it look so good! im about to mod my fly 50 soon like no other, i have some crazy plans but hopfully it will work.. lol but anyways great scooter!
@1drunkparrot avatar
2007 LX150 Dragon Red
Very cool
@vollgashero avatar
@vollgashero avatar
How did you get the head light cover thingy off? I'm trying to replace my bulb but i don't wanna break anything trying to take it off.
Asking in a new topic might have been less irritating, especially for those on dial-up who pay for the time on line.
Necro-posting (which you seem to be 'good' at) can sometimes be very reasonable - and sometimes not. Please:
@micbergsma avatar
@micbergsma avatar
take the mirrors off, you will see a screw below the headlight and two on the back below the controls... I think that's all since I don't have fly for a year now.
@vollgashero avatar
@vollgashero avatar
Oh okay thanks! I got it off, but the bulb the scooter store gave me didn't fit. So now i gotta go back, kinda annoyed. but thank you.
http://photos-a.ak.fbcdn.net/hphotos-ak-snc3/hs475.snc3/26062_10150091071940191_531640190_11353901_6024031_n.jpg
@micbergsma avatar
@micbergsma avatar
right on, can you take a pic of the bulb? I want to see if it's h4 or a weird looking one
@vollgashero avatar
@vollgashero avatar
Sure. The one i got from the store is supposedly the one that comes stock on the Fly 150, so we (sales men and i) thought that it would fit in the 50.
Stock bulb:
http://photos-h.ak.fbcdn.net/hphotos-ak-snc3/hs455.snc3/26062_10150092125415191_531640190_11358797_1164912_n.jpg
After market bulb:
http://photos-a.ak.fbcdn.net/hphotos-ak-ash1/hs425.ash1/23542_10150092131775191_531640190_11358814_3391309_n.jpg
@vollgashero avatar
@vollgashero avatar
Stock bulb:
After market bulb:
Also thanks for the help man.
@micbergsma avatar
@micbergsma avatar
Ah yeah I knew it! That is a 35watt bulb.. Not that great. Aaron who started this thread, we talked about how to change it to hid bulb, I am gonna email Aaron about this..
@vollgashero avatar
@vollgashero avatar
Oh okay.. now what exactly is an HID bulb? Is it the full kit? Cause i am planning on getting a new scoot soon so i decide not to do any huge projects on this one, but bulb replacements and such. I am planning on just buying LED replacements for the turn signals (front and rear), LED running lights (lower front lights), LED tail light, and finally just an upgraded bulb that doesn't cost too much but improves lighting a bit.
@micbergsma avatar
@micbergsma avatar
ah buy a new bike soon... just forget about HID kit.. replace stock bulbs for LEDs will be fine... easy job... when you get a new bike then do HID that way.. google "HID headlight" they will tell you what it is
@micbergsma avatar
@micbergsma avatar
talked with him... he said he thinks headlight bulb is s2
@vollgashero avatar
@vollgashero avatar
Oh okay, thanks man!
@daniellevis avatar
LX 150
@daniellevis avatar
LX 150
Can anyone with electrical experience explain to me why the stock blinker negatives aren't necessary to blink lights in this version of the euro signal mod? Should the negatives be worked in somehow? Just curious.
@junglizt1210 avatar
Vespa 50 Special, Honda CG125
Rant over
which cities are they doing that in? just so I know 8)
ty
[ Time: 0.0142s ][ Queries: 4 (0.0069s) ][ live ][ 339 ][ ThingOne ]
