Stebel Nautilus installation on BV 500
Also pdxscoot helped me by saying that I could add the horn in addition to the factory horn and keep both horns on the scoot.
First Friday night I took the bike apart. I followed all the steps posted by Chetwynder above. NOTE: The 2009 BV500 model is different for the screw behind the crest. After you remove the crest you remove a small screw (not shown in Chetwynder's post). Then you push up on the chrome strip and remove the chrome. Then you'll find the screw that is the same as the one behind the crest on older BV500 models.
In addition to what Chetwynder did I removed the gas cap and trim rubber from the gas filler and took off the piece that covers the gas tank. (This would make it easier to route wire to the battery later.
Friday after removing the panels I could not find the factory horn. (I still don't know where it is). I played around with where to put the Stebel and left it at this point.
