I'm trying to find a post on modern vespa regards to. Some one changing there rear red lights with Led units can any one here help me track it down I think it also had photos to cheers
Try this
German Gilera Fuoco 500 (Post 356159) I tried to get these, even asked my Scootertrap mate, but alas, we both failed to obtain them |
Posts: 46424 Location: Pleasant Hill, CA |
The rear lights and brake lights on the GP800 are LEDs. I bet some bits from that could be used. They look very good from the back. My GP800 is having an ECU update done at the moment, so can't eyeball to check if they are directly swappable.
I wouldn't even attempt to change the Fuoco's rear lamps for LEDs using the original reflectors - if it's for longevity's sake that really isn't a problem. |
[quote="jimc"]The rear lights and brake lights on the GP800 are LEDs. I bet some bits from that could be used. They look very good from the back. My GP800 is having an ECU update done at the moment, so can't eyeball to check if they are directly swappable.
I wouldn't even attempt to change the Fuoco's rear lamps for LEDs using the original reflectors - if it's for longevity's sake that really isn't a problem.[/quote Okey dokey cheers peeps |
I agree with Jim, as I tried it. I had some LEDs in the garage and tried them in the brake lights as well as tail lights. You only get a small circle of light coming from the LED, not the full spread of light you get from the bulbs. This is because the bulbs shine light backwards onto the reflector. LEDs only shine forewards.
Soeley wrote: I had some LEDs in the garage and tried them in the brake lights as well as tail lights. German Gilera Fuoco 500 (Post 356159) Wayne B |
Sorry, I should have made myself clearer. Yes they were the aftermarket single LED bulb replacements.
Sorry for the confusion |
There are LED's out there somewhere that would work great,the trick is finding em.Also too you can get led's that have the lighting on the sides too. The biggest obstacle is not knowing what to order,trial & error is about the only way to find em.When you do finally find em,you will be more than happy with the results.A big plus too is the more led's you can have the more wattage available for other electrical stuff,should you choose.
IMHO
I would never use LED's for the tail or brake lights, unless the scoot came with them from the factory or like Wayne's post where the lights were from an Aprilia. I found that LED's are great when they are designed by the manufacturer but are lousy aftermarket substitutes for bulbs. Most aftermarket LED's on scoots or motorcycles cannot be seen in bright daylight by bus / truck drivers that sit up higher. They are OK at night but how often do you drive around at night? LED's also change intensity with temperature. They get dimmer when it's cold and brighter when hot. A lot of cars have LED's that are bright but those LED's are high wattage LED's so there is little gain if your trying to save wattage. The high wattage LED's also need a heat sink to keep the internal temp from burning themselves out. They do last a long time though. |
MP3 500, Kawasaki Versys, KLX250S, Buddy 150 Pamplona
Posts: 432 Location: Seattle |
I changed my brake lights over to LEDs a month ago and am very happy. After a following rider told me my brake lights were not working (they were) and then nearly being rear ended by a cage I wanted brighter lights back there. I ordered a set of 1156 Wide Angle Hyper Bright LED Bulb - Red from BikerHighway. I just checked and cannot find it on their website any longer but they may still carry them. Failing that these look like the same ones
http://cgi.ebay.com/ebaymotors/HYPER-BRIGHT-WIDE-ANGLE-1156-RED-LED-BULB_W0QQitemZ370196426590QQcmdZViewItemQQimsxZ20090503?IMSfp=TL0905031010008r8244 As the name implies, some of the LEDs in this cluster are pointed at an angle to improve the side on visibility. I snapped a couple of pics on my phone to show you what it looks like at approximately 45' and from directly behind.
I put a set of them in my Chinese scoot a couple of years back, and in a garage or dim light they worked OK. But in bright sunlight they didn't seem to be as bright as regular bulbs.
And they were expensive too. Just be careful and aware of the cagers in back of you. |
LEDs point in one direction. I put a spinning led light bulb in a bike I had and no one could see it to the side - only straight on. I changed back. Be careful.
After changing one of the bulbs I stopped to compare the comparative brightness of each. The LED was at least 3 times as bright as the regular bulb. Admittedly this was from straight behind in my dim garage but that brightness is not going to be any less in direct sunlight. In fact it was in direct sunlight I had a problem with the original bulbs. I think the contrast between the running lights and brake lights was not enough in daylight that people missed the fact I was braking.
I understand the concern about the visibility from the side but these bulbs have some LEDs angled off to the side to help with that problem. No, it probably does not have the same visible range as regular bulbs but I am more concerned with the folks directly behind me. The light spread from these is enough that anyone behind can see them. Thanks for the concern but overall I think these are an improvement. Maybe not for everyone but the option is out there for those who want it. |
I'd like to see a live side by side comparison of some of these leds with standard bulbs. Cops will write tickets here if leds are much brighter than incandescents. I just want a trouble free replacement for these old bulbs that don't shine too bright.
This site, and others carry these multi-angle leds so maybe the side view issue is partially addressed. http://www.ledlight.com/1156-1157-automotive-led-lights.aspx |
On my X9 and the Chinese scoots I added extra LED's to the license plate to act as additional brake and running lights. This may be an option instead of replacing the regular bulbs with LED's.
Posts: 23518 Location: Harriman, Tennessee, Tn |
corsader wrote: I'd like to see a live side by side comparison of some of these leds with standard bulbs. Cops will write tickets here if leds are much brighter than incandescents. I just want a trouble free replacement for these old bulbs that don't shine too bright. This site, and others carry these multi-angle leds so maybe the side view issue is partially addressed. http://www.ledlight.com/1156-1157-automotive-led-lights.aspx |
old as dirt wrote: corsader wrote: I'd like to see a live side by side comparison of some of these leds with standard bulbs. Cops will write tickets here if leds are much brighter than incandescents. I just want a trouble free replacement for these old bulbs that don't shine too bright. This site, and others carry these multi-angle leds so maybe the side view issue is partially addressed. http://www.ledlight.com/1156-1157-automotive-led-lights.aspx |
She's an I-talian $$-burning machine
Posts: 1859 Location: America, The Beautiful |
Anybody received their LEDs from SIP Scooter Shop?
The site suggests they're waiting for more stock to arrive |
Better option? Blink, Blink!
Yeah, the previously-mentioned type is probably on back order; while these with the blinkers are terrific and plentiful, at this moment.
Guinea Pig
That would be pretty cool, but I'd love to get some feed-back from any end-users...prefer to get positive feedback first before I flash my C.Card.
Thanks sushiman for the update....I may well be tempted |
C'mon, be our guinea pig...
Hey, Dingo
I have those blinker-lights on my sip wishlist for a while now... maybe soon... but kinda cash-poor, at the moment. |
I tried to order those once, but a minimum 100.00$ purchase and there was nothing else I wanted from them.
Sucks
Yeah, that sucks
To get around that somebody needs to "bulk-order" units on behalf of everybody. A bit like splitting the restaurant bill, but us guys on the forum live all over the globe. |
Re: C'mon, be our guinea pig...
sushiman007 wrote: Hey, Dingo I have those blinker-lights on my sip wishlist for a while now... maybe soon... but kinda cash-poor, at the moment. |
jimc wrote: ... if it's for longevity's sake that really isn't a problem. |
Baart-less
Posts: 4499 Location: 56°58'34.49"N x 111°29'38.40"W |
If you want lights you want to go to Custom Dynamics. They have just about every conceivable size shape and color of LED for virtually any application.
http://www.customdynamics.com
As I was saying in the other thread,one needs to get away from the directional pointing LED's.If you want your LED's to duplicate the 360 degree around like the stock bulbs are,then LED's with 360 degree firing lights would need to be used.A LED like below for example.This way the lighting is hitting the reflector lenses just the same.With more brightness though.
Hi Folks;
This site - http://www.superbrightleds.com/led_prods.htm - is also pretty good and has just about every option and color you might want. They even have lots of nice "universal" LED units that can be used to illuminate all kinds of areas and components. Many of their LED bulbs also have 100 degree+ radiating patterns (read the descriptions carefully), so they tend to fill the lense a bit better. Just another option... Zang |
