my px was running good, now the kick starter slides when you try to turn it on, the flywheel doesn't turn . someone tell me that it can the clutch, i remove them and put them in oil for one day, then install it back but it does the same. i also chek the cuadrant for any twist but i dont see anything. any helpp,,,thanks
Posts: 6980 Location: Detroit, Michigan |
pulling the clutch and soaking it in oil isn't going to do anything.
It's all a matter of how much resistance you feel. If you feel NO resistance, your clutch may have failed ...like, catastrophically. The two haves may have sheared the rivets or something ( though, if your bike isn't kitted, this is pretty unlikely ) If there is some resistance, then you may have either 1) the clutch cable too tight or 2) your cork plates are cooked, and you need to rebuild the clutch. |
Make sure you don't have your clutch too tight. Loosen the pinch bolt to your clutch cable and let that little clutch link rod (whatever it's called) go back a little bit and then try to kick it to see if you got any resistance...if so, you just need to tighten the clutch not too tight. I noticed this on my PX 150 motor as well in my Sprint. When I tried to tighten the cable too tight..it pushed the little link rod forward too much and had no resistance on the kicklever...so while you are down there tightening up the cable..place your hand on the kick lever and try to push it down until you get it in the right spot.
,,,,recomendations for the cork plates? or rebuild kit. |
Recommendations ..hmmm
order 1 ) the brass push-pin 2) the brass seperator ring that goes between the two clutch halves ( both are wear parts ) and a set of cork plates for your scoot. Soak the plates for 24 hours before rebuilding your clutch. During the process, make sure that the basket doesn't have notches worn in between the finger areas, where the metal plates could get bound up. Be VERY CAREFUL during removal that you keep the metal plates oriented exactly as they came out. I've heard that one of them has a slight dish to it and you want to make sure it goes together as it came apart. That's my recommendation. |
abmsurf wrote: Comments about,,, malossi clutch kit or motor scooter clutch kit one is a medium kit and the other is a super stock and they both have a stock piaggio clutch and work great. i don't race the gears,(dirt bike style) i engage and lean on it,pull in clutch to grip-change gear-engage and lean on it and so on,taking the rpm's right up BEFORE the bike starts to girgle,thats when i shift. my clutches have not failed(stock) if i do race the gears(dirt bike style) i can smell them |
there is really no point to upgrading your clutch ( unless it's a cosa clutch on a P200, which is far more comfortable to squeeze, using less effort ), unless your engine is kitted up substantially.
Just stay stock. |
