I've drawn a crummy picture.
This is what dawned on me - I've painted and made my cowls all fancy. But the pin and wire seem to be feeding the electricity to the signal at the back (pictured as the red circle on the right and the red wire running to the back where the signal is.
So, where is the negative? It looks to me like the negative end of the circuit goes through the spring loaded clip which holds the cowl to the body. Is this correct?
If so, There are two points on the cowl which can't be painted - where the bolts hold the signal to the cowl (sketched as a dark blue line on the left near where the wire ends) and then the current flows through the cowl itself to the tab back at the front (dark blue square) which the spring loaded clip grabs to. These would need to have bare metal so the negative from the signal can get a connection to the metal of the cowl and so that the spring-clip can make a connection to the metal of the cowl.
Am I getting this correctly? Should I expose some metal where the signal nuts and bolts attach to the cowl and on the tab on the front of the cowl where the clip attaches?
